I first checked Pin39 with the sensors plugged in. Where I got 0V before, now I get 12V on that pin.
12V isn't a good thing, did you mean 5V?
One thing we did not do and need to is checking the motors themselves.
Please do a resistance/ohm test of all the motors.
Can you please note them on the "full back of the chair photo" like so:
1.Name of the connector they are driven by on the main board.
2.Motor type: AC(and value of capacitor if present) or DC.
3.Ohms reading.
If the AC motor in #208 is the bottom one on the chair.
It could be "stuck" due to water reaching it and creating rust etc. on it's shaft/transmission.
It requires inspection and if needed cleaning,
it's " transmission " as well.
About the AC-motor :
1. CN1 on the main board as 5 pins, 3 of which are connected.
How many wires does the motor itself have?
I think there should be 3.
if so ,you need to measure the resistance between them all.
2. Did you inspect/measure the Motor Capacitor? what is written on it?
Warning: The capacitor should be discharged before you handle it,even without power it can deliver a nasty jolt!
3.Did you inspect the mechanics involved is there a belt/gear?
can you post a photo of it?
From your measurements in #212(I assume on the diodes near CN13 and CN14).
1. Your line voltage is about AC119V
2. One(or 2) of the 4 diodes near CN13(marked blue) are probably open circuit or there is a bad solder there.
Please check the 4 diodes "in diode test mode" with the DMM.
If there is a bad one(open both ways) replace it.
Otherwise, redo the soldering around the 4 diodes and
check continuity to/from the diodes.
3. The fact that the control pins have no influence on the presence of the voltage on the diodes near CN13/CN14 and you get the voltages constantly suggests there could be a problem with the Triacs BTA12(marked red) or the circuit driving them.
Please lift-up one side of the resistors (marked yellow) and recheck the voltage on the diodes-You should get no voltage.
If you get voltages it probably means the Triacs are shorted and need replacement.
4. What is written on the device (capacitor?) marked green?
