Sir Nick . . . . .palych65 . . . . .
I'm fully expecting it to be good, but initially check out the pot portions circular calrod heating element at its base plate.
Expecting an ~20'ish ohms reading for a good unit.
Open Line meter reading for a bad unit or else, with there being a CONNECTIVITY issue. BUT, with there being no such condition, if you will test directly at the large RED and PALE WHITEISH wires spot welded terminals, located at the Calrod heating elements ends.
With all of your reported good preliminary procedure, in your having seen that the unit is properly sequencing through its initial start up.
Looks like the next thing to evaluate, is being the NTC thermistor sensor that is being clamp mounted and sealed down within the heaters soleplate, of the hot pot portion.
Look at your 1st photo for its referencing.
It is being clamped in the heat sole plate using a right angle wide bend of a stainless steel bracket and its use of a stainless steel ISO /or/ Phillips mounting screw AND its two lighter gauge black wires that connect to a plug on a mini PeeCee Bee over to the right side. Don't touch its side clips of the Delrin / faux/ nylon as time and heat have dried them out and thereby made them so brittle that they will splinter off, upon there being any attempt of springing them outwardly.
Also leave the two plugs in place .
There is now being need for you to take some more ohmmic readings of connections made into that area .. . . . BUT . . . . I now refrain from my further entries . . . .awaiting / seeing if you ever show up here again.
73's de Edd . . . . .
NOW ARE YOU FULLY BEING ? . . . . .
