Wow, you are superb..
I wish everybody was like you.
We need to stay on the AC side of the circuit board.
I notice on the under-side is four black small components.
These are called diodes and make up a bridge rectifier. This turns AC to DC and gives DC voltage to the other boards.
Next check...
Can you please check for continuity across each diode?
UNPLUGGED, meter in continuity and probe both sides of each diode like the fuse!.
One way will make your meter act similar to the fuse. Reverse the probes and nothing should happen.
This should be the case for all four diodes.
Martin
Next check...
Martin
