from #264 : "jumpers from Pin 32 to 27/28"
It should be 32 to 28/29 !
I'm re-posting the test procedure:
remember to plug in all the connectors( CN1,CN2 can be left open when testing the control board without the motor).
I added some more test points(see pic below) a total of 10 points.
Please measure them in all 3 combinations (we don't plug in two jumpers in!) of pins 28,29
,a table would be best.
1. We should connect the main and controller boards with
CN28.
2. On the main board connect
CN1,
CN2.
3. On the control board connect
CN35 and
MgDetect (the opto circuits).
4. In order to activate and set direction of the AC motor.
Use a short wire in the IC socket pins 28,29 to 5v (pin 32)
(one at a time! see pic below)
5. Start by blocking both limit optos(up and down) simultaneously.
No movement should occur with a short in the IC socket at either pin 28 or 29.
6. Now remove the block from both optos.
We should get movement with the shorts(one at a time) in both directions up and down.
At this stage don't get to the limit points yet, just check both directions of movement.
7. If stage 6 is o.k,
Test that the opto limits indeed stop the movement when reached (on both up and down).
"Long " operation in one direction.
Take care, and remove the short jumper immediately ,
if while testing you see it doesn't stop- so no damage will occur.
