Platforms
Content
o.k so on the main board (with the controller board disconnected) we get
1= 7.5KΩ
2= 3.8KΩ
3= 3.99KΩ
4= 3.99KΩ
2-4 are fine (2x2k=4k).
1 is wrong ! needs checking of resistors values near 1 with the ommeter.
What do you get if you measure the same points on the Controller board(cable between boards disconnected) ?
1= 7.5KΩ
2= 3.8KΩ
3= 3.99KΩ
4= 3.99KΩ
I am not sure what is in that circle. Is that referring to the trace on the outside of the board? 12V or is it circling a word I cannot see? I was using the GND pin on that connector.
An OHM test between the res points and ground shows 0 ohms. No connection between them.
Jonathan,
When using your meter on ohms and you get a reading O.L , that is not zero ohms, it means "Open Loop" or open circuit ...no circuit.
You were partly correct in the latter part of your statement by saying "no connection between them" but as shown in Dorkes reply in #110, he took the first part of your statement and wrongly assumed you had a short.
See how confusing it can be when you give inaccurate replies.
Understand you are learning but it's a point you need to look at and remember.
A simple task....get you meter on ohms, look at the scale with the leads apart......O.L ....open circuit
Then join your leads together ........ usually about 0.2 ohms ......meaning a closed circuit.
Your meter will never read zero ohms on ohms scale.
Thanks BlueJets. I knew there was something I was missing in that. I already repeated the test. It reads O.L. Open circuit for all points. now. Here is the IC for your inspection. If your display is as nice as mine it should be pretty crisp.
View attachment 24081View attachment 24082
