What's that black dust in monitors?
G
Glen Walpert
Or do you propose another source of carbom PM2.5 particles, which is a
primary alternative candidate to nitrogen dioxide for the "brown cloud"?
Diesel engines are certainly a major source of carbon particles fine
enough to disperse for thousands of miles, as are fossil fuel power
plants, wood cooking fires, and jet engines.
According to a Sept 2003 article in Photonics Spectra, "particulate
matter in the form of soot is one of the most significant pollutants
from jet engines". A soot measurement system is described, and a 3D
time/position/concentration plot is shown where the soot concentation
in an engine peaks at 4 mg/m^3 during run up to full power with steady
state full power emissions of 0.3 mg/m^3. They do not identify which
engine but do state that the system is being used to test new engine
designs, so this is probably about as good as it gets today. Note
that this soot is essentially invisible to the eye; jet engine exhaust
normally looks perfectly clear. (The particles are detected optically
after heating them to incadesence with a laser).
I have also seen references stating that emissions from wood fires and
fossil fuel combustion in India, China and Indonesia block up to 10%
of sunlight from reaching the surface of the earth for around 1000
miles downwind, an effect believed significant enough to alter long
term weather, and that soot is found in all recent snow/ice deposits
in Antartica.
Bottom line is that if you live on planet earth you cannot get away
from fine soot in your air unless perhaps you work in a good
cleanroom.
Regards,
Glen
DarkMatter
Finally, someone makes a correct observation.
Just like pollen.... thousands of miles. Thank you.
DarkMatter
cleanroom.
Exactly.
Also, and that which accumulates inside a monitor case is not an
emission from within the device. It is an attracted accumulation,
drawn from the air.
It isn't "It's coming from the FBT..." as one uninformed poster has
stated.
Rod Speed
in Antartica.
from fine soot in your air unless perhaps you work in a good cleanroom.
Or live on a pacific island.
Rod Speed
Don Klipstein said:
Rod Speed wrote
So when brownish air looks like the "usual brown cloud"
Nope, nothing like a cloud at all. Just a brown haze on the
horizon. With it visibly decreasing with height above the horizon.
but is less opaque than usual
More than the usual haze effect outside big citys.
but has the nitrogen dioxide brown color,
Nope, much ligher than that.
you are going to say it's not brown cloud
Yep, no 'cloud' at all.
and therefore nitrogen dioxide does not cause visible air pollution?
I JUST said that its not NOx, its the just particles
in the air. Just like all haze effects are. And the
evidence for that is that it goes away after heavy rain.
If it really was due to NOx, it wouldnt.
And how does that disprove either sort of
brownish air being tinted by nitrogen dioxide,
YOU made the claim that its tinted by NOx, YOU
get to do the proving. Thats how science works.
If it was actually due to NOx it would be quite transparent.
It aint, so its clearly due to particles in the air, not NOx.
and how does that disprove presence
of fine soot particles in the air?
Never ever claimed that either.
I JUST rubbed your nose in the FACT that the jet black soot
seen inside monitors adjacent to the FBT is also seen in monitors
where there is **** all soot in the air at all, most obviously with
pacific islands, and so that cant be where its coming from.
Basic logic.
I did claim even less can make visible air coloration,
What matters is whether the concentrations that you
can get with thunderstorms are visible. They aint.
and thunderstorms are easily 4 miles wide.
Not the downdrafts out of them they aint. And while you
can certainly get some NOx formation in thunderstorms,
you certainly dont get entire 4 mile wide downdrafts from
thunderstorms with significant and visible NOx levels.
Look further down than the first paragraph then!
No point when the first para clearly says ARE THE PRINCIPAL CAUSE
If you still say that this document does not also say
that nitrogen dioxide gives "brown cloud" its color
The first para clearly says PARTICLES ARE THE PRINCIPAL CAUSE
Even you should be able to read and comprehend that in the first sentance.
than I will call you a liar!
You can do anything you like, including stand on your
head and whistle dixey if thats what turns you on.
Might be better to look up the correct form, 'principle' instead tho.
You are stuck on "badly setup" or "very badly setup"
ones, while ones not so badly set up make fine soot!
Wrong. Because that stuffs the fuel economy. Soot is
always the result of incomplete combustion and that
always indicates less than efficient use of the fuel.
In the fourth paragrph or so, that page says:
"Nitrogen dioxide and sulfur dioxide gases from burning
of fossil fuels also contribute to the brown cloud.
Pity para 1 says
"Extremely small particles are the principal cause of the brown cloud"
Nitrogen dioxide gas is brown, giving that color to the haze."
Pity para 1 says
When sometimes they are small enough to preferentially scatter blue light?!
Diesel exhausts dont have anything like the same volume of hot
gases required to make it rise to anything like the same extent.
Besides, when smoke reaches 1,000 feet or a few thousand feet
it's usually mainly for reasons other than heat from the source.
Wrong. Thats why you get the inversion effect.
Of course a cloud of particles fine enough to
preferentially scatter blue light will look brown to
transmitted light, but how does that make carbon brown?
Never said it does. YOU were the one waffling on about
soot from diesel engines having a damned thing to do
with the completely irrelevant 'brown clouds' that dont
have a damned thing to do with THE JET BLACK
SOOT THAT CAN BE FOUND INSIDE MONITORS.
Or are you now going to claim that carbon is brown?
Corse not.
You seem to have this hangup on diesel engines
setup badly enough to make really coarse soot!
Because properly setup diesel engines dont produce soot.
I said diesel engines as an example and not as a limitation!
Pity its a trivial source of carbon particles, even in big citys,
and clearly cant be where the JET BLACK SOOT FOUND IN
MONITORS IN THE PACIFIC ISLANDS IS COMING FROM.
I also said oil heated buildings as an example and not as a limitation.
Pity you STILL havent managed to propose where purported soot
in the atmosphere WITH PACIFIC ISLANDS is coming from.
And since whats seen inside monitors on pacific islands is
no different to whats seen in monitors in big citys, its just
a tad unlikely that its actually coming from the air at all.
Basic logic.
And your favored http://www.phoenixvis.net/causes.html
says that offending particles stay in the air for days!
Doesnt say a damned thing about PACIFIC ISLANDS
WHERE THE SAME SOOT IS FOUND INSIDE MONITORS.
Only perfectly ideally,
Wrong. Anything on the lean side of no soot will still have no soot.
which many don't do! If .1% or ,01% of the carbon becomes
soot, that's not going to significantly impact fuel economy!
Basic logic.
Above you say:
That page says over half your favored PM2.5
Taint 'my favoured PM2.5' That just
produces HAZE and aint SOOT.
is caused by gasoline and diesel vehicles.
Pity that aint SOOT thats as visibly
SOOT as is found inside monitors.
Other pages I already cited giving causes of "brown cloud"
color other than nitrogen dioxide say it's carbon particles.
Doesnt matter a damn what some pig ignorant repetition
claims, what matters is that its actually PARTICLES that
that the 'principal' cause of brown cloud, and that aint
anything like the SOOT found in monitors.
AND EVEN YOU SHOULD BE ABLE TO GRASP THAT
PACIFIC ISLANDS DONT GET THAT POLLUTION
BROWN CLOUD EFFECT AT ALL, so it cant be that
thats getting into their monitors.
Basic logic .
If dust can come to Florida from the Sahara
Desert enough to affect air transparency,
Even you must have noticed that dust aint soot.
and if PM2.5 stays in the air for days,
And that aint soot either.
8
then how far does a monitor need to be from sources of
airborne carbon particles to disprove the stuff being carbon?
The pacific islands will do fine BECAUSE THEY DONT HAVE
THOSE BROWN CLOUDS DUE TO POLLUTION AT ALL.
Basic logic.
So you propose gasoline, home heating oil and and natural gas
being the main cause of airborne carbon particles in "brown cloud"?
Nope, I dont give a FRF what the cause of 'brown cloud' is,
BECAUSE THAT AINT SEEN IN THE PACIFIC ISLANDS
WHERE THEY DO SEE THAT SOOT INSIDE MONITORS.
DarkMatter
Not that heavy pollution smog being discussed you dont.
Not that heavy pollution smog being discussed you didnt.
You are the only retard that added the word "heavy". The
discussion, as I recall, is about that particulate which IS able to
stay aloft for vast distances. DOH!
K
Keith R. Williams
Yes, but you are a goddamned idiot. All you can interpret are the
convolutions in your shit.
You really haven't a clue! I thought you were a game from an
senior-adolescent. The exhaust from diesels contains significant
carcinogenic materials. It *will* be regulated severly soon.
They are *not* in any way cleaner than modern gasoline engines.
The latter has had the bad stuff regulated out of them for
*decades*.
Yes, I do.
You lie a lot too.
Said the usenet retard that follows people around like a puppy
dog... no... a cockroach. Yeah... that's it... you're a cockroach.
Wow, he didn't use one swear word. Perhaps I'm having an effect!
Said the retard that hasn't made a viable contribution in months.
Dream on, wannabe!
Don Klipstein
I talk about air that is colored brown but transparent, transparent
enough for you to say, "Yep, no "cloud" at all" and you say it's
particles. I am talking about brownish air that does not preferentially
reflect blue. Brown tint more than haze, and not preferentially
reflecting blue light. And my experience is that rain does dissolve NOx
and reduce its presence in the lower atmosphere; that's a major mechanism
for getting nitrogen compounds into the soil!
What about that http://www.phoenixvis.net/causes.html that you toss at
me?
And you have yet to refute my claims of the existence of more
transparent brownish air other than to say the brown tint is from
particles or that it didn't occur.
Transparent tinted brown air = NO2
Hazy brown air = NO2 plus particles
But soot does exist in the air over the Pacific islands. You point out
Ken's claim of sooty monitors there, and he mentions studies that say soot
exists in the air there and everywhere. And your
http://www.phoenixvis.net/causes.html sure mentions "PM2.5 particles
containing carbon, like soot from tail pipes", and mentions that PM2.5
particles can float in the atmosphere for days!
Basic logic.
I was talking about updrafts that settled slightly downwards after
flowing from the top of the cloud. (Updrafts that move outward
hrizontally from the cloud top without any subsequent downward motion
are usually "anvil cloud".) I was talking about big puffs of transparent
brownish air that I have seen to the sides of the upper portions of some
thunderstorm clouds.
The fourth para still says NO2 is what causes the color! Do you not
comprehend that?
You snip out my mention of only small fractional percentage of the
carbon remaining uncombusted not doing much damage to fuel economy. Heck,
they sure tolerate some carbon monoxide coming out the engine! Carbon
monoxide has even been used as a major component of some fuel gases in the
past!
In addition, there have gotta be plenty of engines somewhere between
"badly setup" and "maximum possible combustion efficiency". And surely
plenty of engines run richer than the ideal for maximum combustion
efficiency to get more power from a given size engine!
Pity para 1 says
Pity para 1 says
How does that deny the fourth paragraph saying that nitrogen dioxide
gives the cloud its color? You have failed to refute nitrogen dioxide
being able to cause a brownish color in city-sized pieces of atmosphere!
No, inversion effect is usually caused by the lowest portion of the
atmosphere being cooled by ground that cooled overnight by radiating into
space. Sometimes also by warmer air at higher altitudes coming in from
aloft. And in high pressure areas where air is sinking, a stable air can
be exaggerated into an inversion. But mostly the lowest few thousand feet
cool overnight, and the lowest few hundred feet cool a lot overnight.
And a couple hours of sunlight can cause convection within a layer of
air that is below an inversion. Wind causes turbulence that can mix air
throughout all altitudes within a couple thousand feet of ground. So,
depending on time of day, smoke can rise a few hundred to a few thousand
feet whether it has no heat to support it at all or has a 6-alarm fire
under it.
You said the brown clouds had to be particles other than diesel engine
soot in opposition to my claim that soot from diesel engines (and not
excluding other sources) can be what turns up inside monitors!
Corse not.
You claimed that brown clouds were brown from particles instead of
nitrogen dioxide. Most of the web sites you say support such a claim,
to the extent they mention what the particles are made of, say that
carbon particles are a significant factor.
http://www.transportation.anl.gov/engine/soot.html sure seems to support
a notion that I have seen in newspapers over the years that some soot
output from diesel engines is common to outright normal. I am sure I can
find more if you force me to do a web search taking more than the 20
seconds that I spent to find that one.
Basic logic.
Doesn't have to say "Pacific islands". It does say the stuff stays in
the air for days. Does that not indicate it can float in from
populated/industrial areas thousands of miles away? And that Ken that you
liked to cite says that the air in the Pacific islands does contain soot
(and cited studies, indicating jet engines as another source) and he
sure thinks that's probably where the monitor black dust comes from!
http://www.transportation.anl.gov/engine/soot.html sure seems to say that
it's normal for diesel engines to produce soot, and discusses extra
measures (other than a leaner mixture) to reduce soot output.
Basic logic.
http://www.phoenixvis.net/causes.html mentions soot from tailpipes as a
major component of PM2.5 and says the stuff can stay in the air for days.
That page does give "soot from tailpipes" as a prime example of PM2.5!
Soot that fine is still soot and is still black when precipitated into a
visible mass!
http://www.phoenixvis.net/causes.html says much of it is soot from
tailpipes (along with the brown color of "brown cloud" coming from NO2).
Basic logic .
http://www.phoenixvis.net/causes.html says fine soot stays in the air
for days, and that is long enough for it to travel thousands of miles.
Soot of PM2.5 size is in the air according to
http://www.phoenixvis.net/causes.html and can surely travel just as far as
non-soot dust!
8
Your favored http://www.phoenixvis.net/causes.html says much of it is!
Basic logic.
NO2 gets diluted to invisible concentrations before traveling that far,
and particles much larger than PM2.5 (PM10 is a major haze component) can
mostly fall out before traveling that far, and PM2.5 gets diluted to a
small fraction of its concentration in urban areas, but there is still
soot in the air there as Ken points out! Or do you make some claim that
monitors in the Pacific islands accumulate black sooty dust *as quickly*
as they do in Philadelphia?
- Don Klipstein ([email protected])
DarkMatter
Major snip, something you guys should learn to do.
http://www.bol.ucla.edu/~agent006/smog.html
Look friggin' brown to me. Have "Dipstick "Slow" Speed" take
a gander at that one. Even looks miles thick.
Will that idiot ever give up his bullshit position?
Rod Speed
Don Klipstein said:
transparent enough for you to say, "Yep, no "cloud" at all"
You didnt, you waffled on about 'brown clouds', which just happen
to be completely and utterly irrelevant to what was being discussed,
where that jet black soot inside monitors comes from.
Air that is colored brown but transparent, in spades.
And you clearly originally said 'fairly transparent' and you
have now attempted to slither off to just 'transparent'
Even you should be able to grasp that that cant possibly
the be source of the jet black soot seen inside monitors.
and you say it's particles.
Crap. I said that the brown haze I WAS TALKING ABOUT is
particles and http://www.phoenixvis.net/causes.html clearly
says that particles are the 'principal' cause of 'brown clouds'
I am talking about brownish air that does not preferentially reflect blue.
Pity its completely and utterly irrelevant to what was being discussed,
WHERE THE JET BLACK SOOT SEEN IN MONITORS COMES FROM.
Brown tint more than haze, and not preferentially reflecting blue light.
What about that http://www.phoenixvis.net/causes.html that you toss at me?
It clearly says that the 'principal' cause of 'brown cloud' is particles.
existence of more transparent brownish air
Which just happens to be completely and utterly irrelevant
to what was being discussed, WHERE THE JET BLACK
other than to say the brown tint is from particles
It clearly is with THE HAZE WAS TALKING ABOUT.
Wrong. And you initially said 'fairly transparent' anyway.
The brown is just the particles.
And its all completely and utterly irrelevant to what
Bullshit. And clearly at nothing like the levels seen
in major citys, so you should see significantly less
of that jet black soot inside monitors used on
pacific islands than in major citys, and you dont.
Basic logic.
Your terminally silly 'soot magnet' theory has blown up in your
face and covered you with black stuff very spectacularly indeed.
You point out Ken's claim of sooty monitors
At nothing like the levels seen in major polluted citys.
And your http://www.phoenixvis.net/causes.html sure mentions
"PM2.5 particles containing carbon, like soot from tail pipes",
Pity the pacific islands dont even get those
'brown clouds' that it is clearly discussing.
and mentions that PM2.5 particles
after flowing from the top of the cloud. (Updrafts that move
outward hrizontally from the cloud top without any subsequent
downward motion are usually "anvil cloud".) I was talking about
big puffs of transparent brownish air that I have seen to the
sides of the upper portions of some thunderstorm clouds.
Pity the NOx levels seen in thunderstorm clouds aint even visible.
Pity about the first para.
Do you not comprehend that?
I didnt snip it out, it was quoted where it appeared, much further down.
Heck, they sure tolerate some carbon monoxide coming
out the engine! Carbon monoxide has even been used
as a major component of some fuel gases in the past!
All completely and utterly irrelevant to where
the jet black soot seen inside monitors even on
pacific islands with **** all diesel engines in use.
Basic logic.
Basic logic.
Reams of your completely irrelevant crap
about 'brown clouds' flushed where it belongs.
Doesnt have a damned thing to do with what was
being discussed, WHERE THE JET BLACK SOOT
FOUND INSIDE MONITORS IS COMING FROM.
Yep.
portion of the atmosphere being cooled by ground
that cooled overnight by radiating into space. Sometimes
I didnt even comment on what CAUSES an inversion,
I was just saying that its the inversion that inversion
effect that produces smoke reaching only that level.
So, depending on time of day, smoke can rise a few
hundred to a few thousand feet whether it has no heat
to support it at all or has a 6-alarm fire under it.
Have fun explaining why it rises.
You said the brown clouds had to be particles other than diesel engine soot
Lie. I JUST said that diesel soot can only be a tiny part of
the total number of particles that produce a 'brown cloud'
Pity it does even on pacific islands with **** all diesel engines.
Basic logic.
Reams more completely irrelevant crap that has no relevance
what so ever to where the jet black soot found in monitors on
pacific islands with **** all diesel engines, flushed where it belongs.
does say the stuff stays in the air for days.
Where ITS CLEAR VISIBLE AS BROWN CLOUD.
It obviously aint with pacific islands that
dont even get the brown cloud effect.
Does that not indicate it can float in from populated/
Nope, because it clearly isnt a visible BROWN CLOUD there.
And that Ken that you liked to cite says that the air
in the Pacific islands does contain soot (and cited
He didnt cite a single study and the OTHER individual that did,
didnt say a damned thing about the levels seen with pacific islands.
AND we just happen to have an atmospheric monitoring
station in Tasmania, whose primary role is to monitor
the levels of greenhouse gases AND THEY DONT
FIND SIGNIFICANT LEVELS IN THE AIR THERE.
So your terminally silly 'soot magnet' theory has blown up in your
and he sure thinks that's probably where the monitor black dust comes from!
Doesnt matter a damn what he may or may not 'think'
What matters is that the measured soot levels are **** all
compared with what is seen in major polluted industrial citys
and since the same effect with jet black soot seen inside
monitors happens in both, it cant be your terminally
silly 'soot magnet' theory that explains that.
Basic logic.
Reams of irrelevant crap about diesel engines flushed where it belongs.
Pity pacific islands DONT GET THOSE BROWN CLOUDS ITS DISCUSSING THERE.
Soot that fine is still soot and is still black when precipitated into a visible mass!
non-soot dust!
but there is still soot in the air there as Ken points out!
Pity about the scientific measurements, whatever Ken claims.
Or do you make some claim that monitors
dust *as quickly* as they do in Philadelphia?
I doubt anyone has ever bothered to measure that.
Don Klipstein
You claim particles and in the past claimed it's dust and not jet black
soot. You are ignoring my pointing out that your favored
http://www.phoenixvis.net/causes.html says as I claim that the brown color
is from nitrogen dioxide and that plenty of soot is present. You seem to
think that your favored web page saying particles are the principle cause
of the cloud negates that same page saying nitrogen dioxide gives the
cloud its color.
Relevant to you saying brown cloud pollution is, depending on when you
said it, dust or particles, and other than jet black soot which I assert
and your favored http://www.phoenixvis.net/causes.html says is a major
component of "brown cloud" urban air pollution.
Basic logic.
Did anyone claim that it builds up as fast in the Pacific Islands as it
does in Philadelphia? No, only that it occurs there! Significantly less
than what I see in Philadelphia can easily be a black covering of the
stuff! Heck, I have seen the stuff a couple millimeters thick in
some trashed TV sets in Philadelphia! A hundredth as much is more than
enough to be quite a noticeable totally black coating!
I did not say they get brown clouds, and you don't need a brown cloud to
get a coating of black soot on things that attract it!
Then what do you claim is the transparent brownish stuff that I saw
blowing out of the upper regions of some of them? You have yet to offer
any evidence that NO2 is invisible in air masses several miles wide better
than noting that a web page I have known you to favor says the principle
cause of "brown cloud" is particles, and you have yet to refute that same
web page saying that NO2 gives "brown cloud" its color!
<SNIP lead-up to this that reverts back to
http://www.phoenixvis.net/causes.html>
Need anyone say more?
Basic logic.
Carbon particle output being totally not tolerated because it reduces
fuel economy according to you even while significant CO output is
tolerated, as an argument that engines can't be producing any fine carbon
particles, is relevant.
Basic logic.
Relevant because they do make soot and relevant because the soot does
easily travel thousands of miles and relevant because Pacific islands do
get some of the stuff!
And nearly enough the same level whether a smoke source has no heat
source under it all or a 6-alarm fire under it!
Turbulence in the air layer below the inversion due to wind (common to
extend upward hundreds of feet and sometimes extends up a couple thousand
feet), and convection within the air layer below the inversion if sunlight
is reaching the ground.
And your favored http://www.phoenixvis.net/causes.html sure seems to
think that soot particles from tailpipes are a major part of the
particulate content of "brown cloud". Do you propose that it's all coming
from gasoline engines (I only said diesel as an example and not as a
limitation anyway)?
Basic logic.
It doesn't magically precipitate when wind blows the air somewhere else
and dilutes it!
So you bring up greenhouse gases? And significant levels of what? And
what do you call significant - monitors accumulating whatever it is at 1%
of the rate I have seen TV sets get in Philadelphia would have no problem
accumulating a noticeable totally jet black layer of the stuff!
from!
Basic logic.
1% of what TV sets accumulate in Philadelphia is more than enough to
form a noticeable jet black layer of the stuff!
You don't need brown clouds to get a fraction of a percent of the
average soot content of Philadelphia air!
You don't need brown cloud to get half a percent of the average soot
content of Philadelphia air, and a monitor getting half a percent as much
of whatever I have seen in TV sets in Philadelphia will get a noticeable
<SNIP a couple additional batches of back-and-forth that so far have ended
with Rod Speed closing with the like of "Pity pacific islands DONT GET
THOSE BROWN CLOUDS ITS DISCUSSING THERE".>
Don Klipstein
He says that pollution can get bad enough to reduce sunlight by 10% a
thousand miles away and that soot turns up in all recent ice and snow
deposits in Antarctica.
Given that I have seen TV sets with jet black stuff a couple millimeters
thick (eyeball estimate) in Philadelphia and that half a percent as much
would be a noticeable totally jet black layer that puts a noticeable black
smudge on anything you use to wipe it off with...
Steve
Jackie said:
What is that fine black 'dust' one sees inside monitors
wow, what a thread, congratulations Jackie, such an unassuming
question too!! Here's my $0.10. (can't get anything for 2 cents these
days!)
the "airflow" argument;
The air-con for our room is pumped in under the "computer flooring"
and the only outlet is through the holes in the top and bottom of the
racks. Hence, the air-con for our area is FORCED THROUGH all our
electronics out the top of the racks into the room.
Our monitors still get a good coating of black dust, despite constant
air flow. Albeit, probably a fairly low cu-ft/min rate.
the "adjacent parts" argument;
Black dust can be found on the following; the CRT, the anode cap and
HT leads, the FBT/Tripler, adjacent metal shields, adjacent circuit
boards... AND in LARGE QUANTITIES on the inside of the lid adjacent to
the anode cap. Some have suggested that the dust does not appear on
adjacent parts of the case. This is just plain wrong. Perhaps this
is related to the upward direction of the airflow in our area.
I have heard of "hermetically sealed" car ignition components being
opened to discover black dust. Where does it come from?!
(http://www.technologie-entwicklung.de/Gasturbines/Russian_APU/Ignition_Box/ignition_box.html)
Negative Ion argument; see
http://www.airpurifiers-uv.com/tech~negativeions.htm
They call it "Black Wall", I like that name!
The equipment I refer to is also two stories below ground in a purely
air-conditioned environment. No fresh air down here at all
(unfortunately), no mysterious brown clouds either.
My conclusion;
It's hard to clean, it smells funny, it gets all over the monitor and
you and it generally sucks. It's the excrement of HT-loving invisible
miniature Aliens for all I care.
It's black dust, get over it people.
niftydog
Rod Speed
Don Klipstein said:
Rod Speed wrote
Reams of completely irrelevant crap about
brown clouds flushed where it belongs.
as it does in Philadelphia? No, only that it occurs there!
If YOU are claiming that it builds up much slower
in the pacific islands than in a heavily polluted city,
YOU have to provide the evidence that thats so.
Basic logic.
Significantly less than what I see in Philadelphia can easily
be a black covering of the stuff! Heck, I have seen the stuff
a couple millimeters thick in some trashed TV sets in Philadelphia!
Dont believe it.
And when you cant do anything better than this pathetic effort,
here goes the chain on the rest of your completely irrelevant
waffling on about what doesnt have any relevance what so
ever to where that black soot INSIDE monitors is coming from.
Nope, thats just the primary role of that sampling site.
Soot in the air.
Reams of desperate attempts to claim that the jet black soot
found in monitors on pacific islands is much lower in volume
than seen in a major polluted city flushed where it belongs.
Pity you dont have a shred of evidence that there is any difference at all.
Rod Speed
days!)
Nope, none of mine have a uniform or anything like that distribution
of the jet black soot all over the inner surfaces of the case.
Perhaps this is related to the upward direction of the airflow in our area.
Or perhaps not when most dont use monitors in any airflow at all.
being opened to discover black dust. Where does it come from?!
If it really is hermetically sealed, it obviously must be coming
from whats hermetically sealed up in that component.
Basic logic.
Dont get that effect here, just dust colored.
in a purely air-conditioned environment. No fresh air down
here at all (unfortunately), no mysterious brown clouds either.
My conclusion;
Mine doesnt smell at all. You're clearly talking about
something other than the jet black soot being discussed.
Have fun explaining why it doesnt with any of my monitors.
and you and it generally sucks. It's the excrement
of HT-loving invisible miniature Aliens for all I care.
You have always been, and always will be, completely and utterly
irrelevant. What you may or may not care about in spades.
Or tell you to go shove your head up a dead bears arse and
rub your nose in the fact that no one is holding a gun to your
head and forcing you to read what you arent interested in.
DarkMatter
You are as mature as a freshly pinched brown load of shit, boy.
That is where you belong. Flush yourself, retard boy.
DarkMatter
Hell, if you call him the "size" of irrelevance, that would make you
4 orders of magnitude smaller than a point source!
