"Winfield Hill"
I see "for use where equipment is already isolated" which is not quite
the same thing as "incorporated into an installation".
** Win is a man who "just sees what he wants to see and disregards the
rest .... "
He even treats drivel written by a marketing puke as reliable tech info.
Yes, auto-transformers don't provide isolation.
** Not the issue.
At all.
Don't tell us about hot vs neutral polarity, or 230 vs 120V, because
all systems, such as Weinberger's wireless receiver unit, need to have
sufficient insulation to protect the user against miswired ac outlets.
** Active - Neutral reversal is not a hazard in itself. Only in combination
with an auto- transformer step-down or other wiring error does it sometimes
becomes one.
BTW
Win,
Best not tell folk what * NOT* to tell you.
For that is the mark of a colossal fool.
If I were Weinberger, going out to buy a transformer, I'd probably get
an isolated transformer.
** Like the one in the URL I supplied:
Sizes start from about 20 VA in wall wart form - eg:
http://www.dse.com.au/cgi-bin/dse.storefront/43eb0fc307c2afea2740c0a87f9c075e/Product/View/M1155
Much better, much safer & ready to use with no effort.
Just beware if the device draws power on one half cycle only - OR its
internal transformer fries running on 50Hz instead of 60Hz.
But if I was in a pinch I'd use Bill Sloman's
suggestion in a second without worry
** Then you would be a dangerous fool indeed !
Using *identical* 115 volt windings in series makes no allowance for
output voltage drop under load.
The OP's auto dialler device was not specified beyond a nominal "6 watt"
consumption rating which may well equate to a 12 VA rating = 100mA rms
draw = up to 250mA peak current pulses. The winding resistance for a 12
VA, 230 volt transformer primary is typically 250 ohms (or 2 x 125 ohms if
split). PLUS the unit may well have an internal iron transformer that runs
heavily into saturation when fed from a 50 Hz supply.
The end result IS the auto dialler device may very well see effectively a
90 to 100 volt supply - not the expected 115/120 - and may not function
properly when it is most needed to SAVE LIVES !!!!
The auto dialler unit may also contain low value film caps from line to
ground - common practice in US appliances - such caps may not may not
tolerate the application 240 volts AC on a *long term* basis without
failure. Not to mention the chances of exceeding the safe max ground leakage
current level prescribed in Europe and Australia.
I certainly have used it many times inside instrument designs.
** An **entirely** different matter to using the same idea linked
externally to some arbitrary, untried 120 volt *only* device.
You really need to learn to think things through better - Win.
In fact, it's safe to say it's a
standard approach for dealing with 115/230V capability.
** Shame the unit in question HAS NOT been designed for such capability.
The only safe conversion method is to use an isolation step-down of
comfortably greater VA rating than the load 120 volt, 60Hz appliance
normally requires.
Then you only have the 50 / 60 Hz issue still left to worry about.
......... Phil
