Hello every one so my friends dad gave me an old computer its from 1990 or 1993 any way I spotted a leaking battery so I disordered it nd there is some damage so I had to remove the din connecter and where the mother board connects an old school 12pin I did this so I could see how far the damage has gone
I'm looking for advise for the lines and tracers as I'm still getting continuity but I can see the corrosion I've cleaned the area with rubbing alcohol and I've scratched off a little of the rust/oxidation
What is a good and simple way to fix this
I am very new to this and my skill level is low
tools and parts available to me
20 watt soldering iron
solder
kynar wire
solder wick/braid
rubbing alcohol
tooth brush
a chap digital multi meter
The back you can see the very bad job I did here
The front
solder
kynar wire
solder wick/braid
rubbing alcohol
tooth brush
The front
