I can actually 'see' the breaks in the track - no wonder you can't measure anything!
The A/C and B/D points will measure 'open' if the ferrite beads aren't in!!! Clean the leads on the ferrite beads and refit them making sure the solder joints are clean. At a push you could just link out A/C and B/D with wire and it wouldn't make much difference....
Solder wires directly from 2-C and A-R31. This will fix the broken tracks.
Assemble and test.
Assemble and test.
