Sir whiteoutage . . . . .
Can someone smarter than me reverse engineer this string?
Why "soitanly ! " . . . . but its now only being possible, with the aid of that photo of that . . . .
actual SUNNY, dial cord drive mechanism.
Now, indeed, that SONYs viewed mechanical structuring, is certainly looking to be service friendly.
Usually on all other units . . . . . you need the dial cord to be loosened and set aside, to be able to pull the chassis and repair it and then figure out how to restring the dial cord . . . . . .
BACK IN THE SAME MANNER. .
BUT, at least, it is
ALREADY being of the proper length, with just the proper routing needed to be figured out.
NOW, The real clincher is that the central main tuning condenser seems to be snap-coupled into the LARGE pulley.
Now you did not show that aspect with another picture, but we might suspect that is going to be by the coupling between
them by a clip in bar that engages into the two
GREEN clips, as is being marked in with the two
GREEN rectangles..
So there could potentially be a 180 degree error in the clipping in of the two parts together.
DIAL CORD STRINGING's DRAW UP . . . . .
My draw up has
REPLICATED RED dial cord paths . . . . but those are being spaced outwards a bit, so as to not block viewing of the original dial cord path from being additionally viewed..
In viewing the long linear dial scale we are seeing that both bands lowest frequencies are being at the left side of the scale.
CHECKS . . . .
In your minds eye, rotate the tuning knob clockwise and then visualize that cord is fed to the right on its rotation. Then, naturally the dial pointer, now at the mid scale point, is ALSO moving down towards the
lower frequencies.
CONFIRMED . . . . . . that the dial stringing is being correct . . . .up to this point.
NEXT . . . . use the tuning knob to run from one extreme end of the dial scale, and then back to the other extreme.
If all is in order and no stopping / lock down of the dial cord and pointer indicator, all is in order.
It is now just a matter of seeing what is not correct in your mechanically mating together the large off white pulley and its " mechanical coupling mate " on the center of the chassis variable tuning capacitor.
Looks like the dial cord also "drags" across a plastic support pillars groove. at left side routing up from second small idler pulley and then at mid span over to the incoming wrap into the LARGE pulley and its terminating tensioning spring.
TEST . . .
Grip that tuning condensers " mechanical coupling member " and then do duly note that it should be able to make a full 180 degrees rotation between its two extremes.
THE MYSTERY SITUATION . . . .
In ye olden tymes . . .tuning condensers had two sets if alum-i-ninny-yum-yum finned vanes that intermeshed and had insulated air spacing between alternate surfacing fins.
You could then see fully meshed fins that would be maximum capacitance in order to tune to the LOW frequency ends stations or totally unmeshed fins / vanes that would be at the extreme other
HIGH frequency end of the dial.
NOT SO, on your mini sized tuning capacitor . . . . it uses mini sized vanes with thin poly sheet spacers between each set of vanes .
Thereby, no chance of bent / shorting fins . . . . . plus higher capacitance in small packaging by using poly as the dielectric insulator medium, vice air.
DISADVANTAGE . . . . .typically, you can't readily view the meshed / un meshed fins / vanes mechanical state.
Its quite glaring . . . on the olde cap styles.
This is all leading into your need now to couple the tuning condenser (? bar / rod ?).
Hopefully you might now expect to run the dial scale pointer to one extreme end ( say the low freq end) and rotate the tuning condensers (? bar / rod ?) to its
PROPER maximum capacitance end setting .
Then you mate the two together . . . . .expecting the two to then snap together !
Then expect tuning to work properly, with proper, full unhindered tuning range.
OR if you made an incorrect extreme positioning of the tuning condenser , expect a limited tuning range, such as you
WERE experiencing .
YET another
LIKELY SCENARIO . . . . . was if you had the dial scale . . . .
NOT . . . .at and end position and then just slapped the two parts together. With the bar then just being haphazardly engaged, to either side of either clip after some degree of rotation. This condition then would be giving you only partial coverage before binding up and stopping, as well as its mis- calibration to stations.
BUT NOW . . . .you apparently have stumbled . . .and that's being heav-eeeeeeeeeee on the STUMBLED aspect . . . back into the units correct re-assemblage.
YE OLDE TYMES . . . . . VIEWABLE TUNING CONDENSER . . . . VERSUS . . . . .NEW UNITS
THAAAAAAAAAAAAAAASIT !
73's de Edd . . . . .
