Ok now what is a lm117 is it a intergrated circut (IC)
Platforms
Content
Nice ring of fire
Where did you get it?
Yep...Ok now what is a lm117 is it a intergrated circut (IC)
Could i pick one up at my lical radio shack
most probably, tho they are more likely to sell the LM317 ( its the same thing)
cost you maybe ~ $2.50
All you'll need is a DC wallwart.
http://www.ebay.com/itm/Adjustable-Power-Supply-Kit-LM317-1725-/370312787016?
No insault taken i am very new to this and i fund it a lot if fun i really enjoy it that kit is amazing but what is a heatsink
Without a heatsink the input voltage range should really be limited on that kit, unless the draw is very low...
Good idea lets put one of those in but how do you install one of those
I repeat my earlier post.....
this project as others have hinted at is well above your abilities. You should be starting with the basics of electronics and learning from there
there are many online electronics tutorials, just google for them, learn what a resistor and a capacitor etc are and what they do in a circuit
then and only then start with some basic circuit building, a battery a LED and a resistor.
from all your comments I'm also assuming you probably dont have a soldering iron and you dont know how to solder ??
This is another skill you will need to learn to do really well else you will also end up with failures in the circuits you build in the future
Dave
Yes google is good i thought it would be better asking experienced people
