Eeyore said:
More than just 'some' my friend.
This guy just gave me a reference btw.
http://www.ibd-uk.com/members/jones-martin.htm
Look at his credentials ! A totally charming chap btw and we think very alike. We
worked on 2 successful projects (one of which I turned round from a 'runaway'
into a full blown commercial success) and stay in occasional contact to this day.
They were radar projects btw lest you think I only do audio.
RADAR, huh?
Here's open-ocean PPI marine collision avoidance I was doing in 1972:
(View in Courier)
TX TRIG>------[MS1]---[MS2]----A
AND Y---A _ _____
RX VIDEO>-----[CLIP]-----------B NOR Y--+-->ALARM
+--B |
| _ A--+
+--Y NOR
B--+---O |
| |<-- SET
[R] O |
GND +V
To start with, the SET switch is made, momentarily, causing the ALARM
signal to go false.
Then, the main bang triggers MS1, the RANGE one-shot, which triggers
MS2, the CAPTURE one-shot, on MS1's trailing edge.
In the meantime, clipped video is applied to one of the inputs of the
AND, the other input being connected to the output of MS2, so that the
AND's output will go true if there is clipped video and a high from MS2
on its inputs simultaneously.
When the output of the AND goes high it resets the RS latch made from
the two NORs, and the ALARM output will go low, causing an audible alarm
to sound, which will alert the RADAR operator (or whoever's on watch) to
the fact that an object has just been detected at the range set by MS1.
JF
