Isolated, regulated, toroidal step down transformer AC power supply design.
Mark
Can anybody point me to a good design of same.
240 VAC in, 9 VAC out.
Mike
The closest thing in terms of a transformer that will be able to
provide 'some' regulation is a ferroresonant one. They were often
used 20 or more years ago but declined more quickly when the UPS
became cheaper.
The yare good at supply regulation but bad for noise and bad for
waveform distortion.
You dont really want to design a ferroresonant in a toroid unless
you want to spend a few weeks getting to grips with the material
properties and all the magnetics calculations and building many
prototypes.
Far better you just get a good SMPS.
But do you really need 9vac for your application or is that to feed
something else that could utilse DC more efficiently ?
or did phil write this so i can practice typing and get even more proficient ;)
Regards
Mike
* VK/VL Commodore FuseRails that wont warp or melt with fuse failure indication
and now with auto 10-15 min timer for engine illumination option.
* VN, VP, VR Models with relay holder in progress.
* Twin Tyres to suit most sedans, trikes and motorcycle sidecars
http://niche.iinet.net.au
Trevor Wilson
**Why don't you tell us what you are trying to actually do, rather than
telling us what you think you need?
As you may have guessed, your request is difficult to satisfy.
At a minimum, you need to tell us:
* AC or DC
* Maximum and minimum current requirements.
Mark
I am trying to build a 240 VAC in (or even 110 VAC in, I really don't care)
9 VAC out, regulated (to 9 VAC) , isolated (from transformer), step down
transformer and AC power supply.
Input fused (at about 2 amps) but I could adapt just about any design to
about that current.
There...but I think I already said it, didn't I ..Let's see?
.... yes, thats me.
.......ah, I did.
Phil Allison
"Mark"
** BEWARE: Top posting fuckwit on loose !!
care) 9 VAC out, regulated (to 9 VAC) , isolated (from transformer), step
down transformer and AC power supply.
** Seeing as you are a COLOSSAL FUCKING MORON with ZERO
ability to provide a intelligent specification
- just what the **** s the application - eh ???
about that current.
** Err - is that 2 amps AC at 240 volts or 120 volts - FUCKWIT ??
** This UTTER ASS is either on an overdose of mild altering drugs
- or damn well needs to be.
PISS OFF TROLL !!!!!!!!!!
........ Phil
James
about that current.
... yes, thats me.
......ah, I did.
What is the application?
Do you need a regulated 9V RMS Sinewave output? What for?????
James
Phil Allison
"James"
** Forget it - " Mark " is an UTTER MORON with idea whatever of the
meaning of the words he is using.
Must be another ADHD fucked " ladder monkey " or some total FUCKWIT
electrician.
........ Phil
Mark
Yes, I really do need 9 VAC for my application.
Within the application, the 9 VAC is rectified, filtered, regulated (to +15
VDC and -15 VDC) and then filtered again.
So the input needs to be regulated to within about (+ or -) 1% 9 VAC.
Phil Allison
"Mark Isley = Utter FUCKWIT "
** BOLLOCKS you do !!
+15 VDC and -15 VDC) and then filtered again.
** This TOP POSTING, PITA DAMN FOOL
has just gotta be a ADD fucked cable installer.
What a bloody HOOT !!!!!!!
Lets all keep this CRETIN on the fishing line as long as possible !!
What entertainment !!
........... Phil
Phil Allison
"Mark Ilsley UTTER FUCKWIT "
has just gotta be another ADD fucked cable installer !!!!
Just like " Spanky" from Melbourne.
What top entertainment !!
........... Phil
Mark
No, I think I want to regulate the output of the transformer.
The output of any transformer is only proportional to the voltage of it's
input. AFAIK, anyway.
So if the volts in aren't nominal, nor is the voltage out.
Phil Allison
"Mark Ilsley = UTTER FUCKWIT "
** ROTFLMAO - this is absolutely CLASSIC !!!
........... Phil
Mark
Doesn't matter a rats arse to my purpose.
Phil Allison said:
"Mark"
....... Phil
Phil Allison
** ROTFLMAO - this is absolutely bloody CLASSIC !!!
Just like that " Spanky" moron from Melbourne.
What a bloody HOOOT !!!!!!!
........... Phil
James
*** Thanks...thats the best laugh I've had for ages :)
I'm sure a single 9Vac supply will give you amazingly clean +/-15V rails,
you'd best make sure you get a 500W toroidal though, that'll help..
PMSL
James
Mark
Bullshit
PMSL
James
