Isolated, regulated, toroidal step down transformer AC power supply design.
Phil Allison
"Mark Ilsley UTTER FUCKWIT "
** ROTFLMAO - this is absolutely bloody CLASSIC !!!
This ASININE, TOP POSTING, PITA DAMN FOOL
has just gotta be another ADD fucked cable installer !!!!
Like that " Spanky " complete moron from Melbourne.
What a bloody HOOOT !!!!!!!
Lets all keep the CRETIN on the fishing line as long as possible !!
What top entertainment !!
......... Phil
Mark
Incapable of argument.
........ Phil
Trevor Wilson
Mark said:
I am trying to build a 240 VAC in (or even 110 VAC in, I really don't care)
9 VAC out, regulated (to 9 VAC) , isolated (from transformer), step down
transformer and AC power supply.
Input fused (at about 2 amps) but I could adapt just about any design to
about that current.
There...but I think I already said it, didn't I ..Let's see?
**WHAT IS THE APPLICATION?
F
Franc Zabkar
Yes, I really do need 9 VAC for my application.
Within the application, the 9 VAC is rectified, filtered, regulated (to +15
VDC and -15 VDC) and then filtered again.
So the input needs to be regulated to within about (+ or -) 1% 9 VAC.
Ask yourself, what is the peak value of a 9 VAC sine wave?
- Franc Zabkar
Trevor Wilson
**You have not told us what you are trying to accomplish. You can expect to
suffer derision, until you explain more fully what you are trying to do. A
regulated AC source is difficult to accomplish and usually unnecessary. A
regulated DC source is much easier.
You should also learn about top posting and why it is not a desirable method
of communication.
Trevor Wilson
Rudolf said:
Why not switch mode?
**Because the clown who posted the original request has not revealed why he
needs 9VAC. An SMPS is the worst way to generate AC in low draw
applications.
Phil Allison
......... Phil
rebel
which removes the need for any tight regulation of the 9VAC.
Nah, THAT's bullshit. (Hint: Just think for a moment what effect an increase or
decrease of 0.5V in your AC 9V will have on the REGULATED DC rails.)
Mark
I am not compelled to explain anything more than what I already have and
what I have explained is more than sufficient for my purpose.
This isn't rocket science. A minimal design AC source can be achieved with
only ONE component but the output is then at the mercy of the vagaries of
the input voltage.
A better design might involve transformation to a nominal VAC (+/- x%) ,
then rectification and regulation to a nominal DC (+/- y%<x) , filtering and
decoupling and then inversion back to 9 VAC (+/- 1%).
Even Google'sperts should be able to understand that.
Trevor Wilson
**You don't have to explain anything. You won't get any help, either.
the input voltage.
**Correct.
and decoupling and then inversion back to 9 VAC (+/- 1%).
**Except that it is ridiculously complex and unnecessary. If you would
explain what you are trying to do, then we can help you.
**I suggest you Google the following: 'Top poster'.
Mark
You are assuming that I had a perfect 9 VAC sine wave input to my
application. If I'd had what I wanted, I wouldn't need to ask the question.
What I DO have is an very imperfect NOMINAL 240 VAC, domestic supply, like
everybody else. (actually more imperfect than most, as we live in remote
rural area with many idiosyncrasies in the supply).
I can step down the domestic supply to (nominally) 9 VAC, but it suffers
exactly the same problems as the domestic supply. i.e. the output of the
transformer isn't 9 VAC and isn't a perfect sine wave.
Phil Allison
"Mark Ilsley = UTTER FUCKWIT "
application.
** No he is not - YOU FUCKING TENTH WIT !!
everybody else.
** Then accept the fact that regulating the AC voltage is NOT required.
Just gotta be a school boy wanker.
........ Phil
Phil Allison
I see, and you do? (decide what others should accept or believe)
** Fucking, know nothing IDIOTS like this arrogant * PIG *
NEVER get to decide what others should accept or believe.
has just gotta be another ADD fucked PIC programmer !!!!
......... Phil
Mark
Good boy, Trevor. At least you grasped that much. An SMPS is not an option
or I would have simply purchased one.
The reason WHY I need 9 VAC is because the application needs it and for
reasons that I have already explained.
I may post a schematic of the applications rectification, regulation and
filtering circuit, but I don't think this is necessary.
Most people can understand a statement like "240 VAC in, 9 VAC out",
regulated to a fine tolerance (Say 1%) and isolated from the toroidal step
down transformer.
Back to Goggle now, like a good little boy.
Phil Allison
"Mark Ilsley = UTTER FUCKWIT LIAR "
** YOU have not explained any such thing -
YOU STINKING AUTISTIC LIAR
** If it already has a " regulation " circuit, the incoming AC does not
also need regulation
- YOU FUCKING TENTH WIT !!!!!!!!!!!!!!
step down transformer.
** It's purest gobbledegook.
......... Phil
Mark
That is an astounding case of the Kettle calling the Pot, "black".
You just accused me of "arrogance" for NOT supplying information (on my
application for the requested design) whilst arguing that your own arrogance
is in fact a power to "decide what others should accept or believe", earned
on the basis of what?
You will claim superior knowledge and experience, but YOUR superior
knowledge experience CAN NOT make ME arrogant, and that is by definition.
Quite to the contrary, it makes your statement look arrogant because you
appear to believe that the power to "decide what others should accept or
believe" is something that can be EARNED by superior knowledge and
experience. That is; it exists AS A RIGHT that can be earned.
No doubt this proposition is TRUE inside THIS newsgroup or it may even be
true inside ALL newsgroups, but it is not true in the wider realm of human
relations or the law, because it is in conflict with the basic tenant of an
individuals free will.
In exercising that free will, I have the right NOT to divulge any
information I consider private (or for any other undisclosed reason) and I
will not let you twist the exercise of that option into an allegation of
arrogance, just as you have attempted to do.
To make that accusation under these specific circumstances is an
abomination.
To infer, by the argument that you have made, that the power to "decide what
others should accept or believe" exists at all as a RIGHT, which can be
earned, is an intrinsically arrogant position to take. It is one that
suppresses all decent.
Can you think of anyone in this newsgroup who suppresses all decent?
Mark
To take exception to the style of postings is such an enormously trivial and
childish position to take that I hardly feel deprived of your advice.
You may consider yourself excused of offering and advice.
Phil Allison
"Mark Ilsley = ASININE FUCKWIT "
and childish position to take that I hardly feel deprived of your advice.
( snip some of the CRAZIEST verbal garbage ever seen on this NG )
This ASININE, TOP POSTING, PITA BLOODY FOOL
What a bloody HOOOT & A HALF !!!!!!!
What TOP entertainment !!
......... Phil
Mark
It's irrelevant, actually.
240 VAC in (nominal) , 9 VAC out (+/- 1%), about 2 amps (but you can make it
10 amps or 1 amp, I don't care), toroidal transformer.
I've already given you sufficient information on the type of circuit it
supplies.
