Hi there. Hope you can help.
I just made an account here to get help on a present challenge I am working on and hope to stay on for future projects I may want to tackle.
My question is this. I got a hold of some very nice full body massage chair. It was in a show room which got flooded by a few inches of water. The chairs were left standing on a shelf for years after this. The PCBs were on a shelf an inch off the floor so the only real damage to these chairs was in the electronics. I have already repaired two of these chairs. One needed a good cleaning and a replacement fuse. The second needed a bunch of resisters, diodes and caps replaced because their leads had corroded right off.
The third is where I'm stuck. I have done a lot of learning through this project and I love learning and working this out.
So far, I have replaced all the resistors, capacitors, voltage regulators, diodes etc with the same value or as close as I could manage between ordering stuff from digikey and scavenging from a heap of other boards I have around.
Problem is this. The remote does not light up when I hit power on it. I followed the circuit and found two possible reasons.
1: The power supply voltage coming in is 12V AC. (multi meter reads 13.5) After the diodes and Cap it the multi meter reads 17 VDC. I should probably state here that the 25V 2200uf cap here was replaced with a 50V 1000uf. I am not sure why there are 17V here. Maybe there is a good explanation for that. That's why I am asking.
2: The remote has four leads. VCC, RT TX and GND in that order. When I check with my multi meter, I get -17VDC at both the VCC and GND. That confuses me. I was not expecting that. I checked all the diodes they are pointing in the right direction, and I suspect that there would be a fuse blown or something if this was not as it is supposed to be.
Can somebody tell me if either of these two is the problem with this board or is there something else I need to check. The boards are all neatly labeled with the part number of the components so there was very little guess work.
Your turn. Ask questions. I can post pictures if they would be helpful ... Don't know that's why I'm here.
Jonathan
Jonathan
