The components on that board look perfectly fine and serviceable to me. And as I said, if the system was designed with the same components replacing any of them can have a very detrimental effect on the way the speaker sounds. Something to consider is that each of the capacitors and inductors has a base internal impedance in addition to the portion of its impedance that varies by frequency. If you substitute, for example, a coil of the same inductance that is would with thicker wire the base impedance will decrease and that can affect not only the level the component it is associated with plays at outside the crossover range but where in the spectrum the output of the speaker rolls off, which will add humps & bumps to the frequency response.
If you had the equipment to measure that you might be able to compensate for that but you would end up for all intents & purposes completely redesigning the crossover before it sounded close to right and you would probably not get it to sound as good as it did before you started tampering with it.
I would suggest that a project like this is beyond the understanding of someone who has not spent some time studying how crossovers work (if you understood them you would be able to knock out a schematic in a few minutes) and then done enough testing in a facility equipped to measure speakers to understand how the theory learned applies in the real world.
The changes you are talking about are akin to someone thinking
1) Cars go faster than bicycles.
2) Cars have wider tires than bicycles
3) Therefore If I modify my bicycle to allow 6" wide tires it will go faster.
Thanks for the responsse.
Not to be dismissive but i have already decided I am doing this and I have already spent on it, some parts arrived some on the way... so its being done. Ill compare and measure the old and new crossovers, DSP them to the same frequency response to within about 0.5dB
Small changes to the frequency response are not a problem as i use DPS anyway to my desired house curve.
I am investigating for myself if crossover components can sound different even if the freqency response remains the same.
What else other than frequency response contributes to the perception of quality/clarity/tone and all those other audiofool terms we hear. i dont want to read about it, watch youtube or listen to anothers opinion on if its worth it or will be a failure.
If its a failure and ruins the sound then i will simply reinstall the original crossover and agree with you that it was pointless and a waste. Untill then i will proceed with the project and learn myself how to draw the crossover diagram.
I was just asking if anyoine could help me with that, thats all I want. I will get there eventually but if its a 2min job for someone else to look at that and save me the hours leaning it then thats all i was hoping for. dont ask dont get
So, again, can anyone help me with drawing this crossover diagram, does what iv indicated so far look correct?
Thanks all,
Mark
