Hello all,
I want to upgrade the crossover in my speakers but one of the Electrolytics that i want to replace is quite a heafty 80uf and id like to replace it with something "better" (Poly, copper foil etc etc)
But i don't see many options for decent poly caps at good prices and basically NONE that i can afford or would even want to afford! for copper foil in this value (some are thousands of pounds for a single resistor and im not that spendy )
If i use 2x40uF in parralel will that equal exactly 80uF (± tollorance) or is there some additional loss/gain by running parallel.
Is there anything im not considering (other than those that will say its a waste of time upgrading capacitors/resistors/inductors as they dont sound different - id like to determine that for myself.)
