The original schematic posted today uses a Jfet-input TL082 dual opamp which has an extremely low input current. I do not know why it is a dual instead of a TL081 single one.
The older NJM4558 dual opamp uses ordinary input transistors with 2500 times more input bias current which reduces the input voltage from the 1M resistor -0.5V maximum which reduces the output voltage a maximum of -0.5V.
The 470nF input capacitor driving the 1M resistor produces a cutoff frequency of 0.34Hz which is way too low, it will pass earthquake or percussion vibrations. I recommend 10nF which has a 16Hz cutoff frequency that passes all audio frequencies and cuts subsonic vibrations. 6.8nF into 1M produces a cutoff frequency of 24Hz and 15nF produces 11Hz which are fine.
Do not use your 1uF capacitor as an input capacitor because its value is 100 times too high (double the 470nF one).
The 1uF capacitor C3 shown is a backwards polarity polarized electrolytic. I would use a smaller 330nF (0.33uF) film capacitor to pass all audio frequencies. Film capacitors are not polarized.
C28 is shown as 220nF which is too low and produces a cutoff frequency of 727Hz. I recommend 3.3uF to pass frequencies above 49Hz.
