Hi guys...I hate to say it, but I need your help again .
As you know, I have been building this circuit rather successfully and have recently installed the stomp switch in prototype mode, successfully.
So I moved on to regular build on a PCB.
This happened twice now:
I get the circuit built and test the pins. Pins have the expected readings.
I then install the stomp box switch.
Now, my Pin 1 has a reading of 7.82 and Pin 2 has a reading of 7.78. Pin 3 has no reading at all.
I installed the stompbox switch according to this instruction (see attached pics)
The only part I have yet to install is the LED because I figured I want to make sure the circuit works before doing so.
Why would I, all of a sudden go from perfect readings to a reading of 7.82 and Pin 2 has a reading of 7.78. Pin 3 has no reading at all.
It may or may not be due to the switch wiring, so I am wondering what are the possible causes for this?
Thank-you
