When a 747 with DU counterweight crashed near where I used to live in Amsterdam,
much of the DU was burned (not found again), and all the firefighters, PLUS the people
sorting and disposing of the junk, have symptoms
But surely there are all sorts of gaseous nasties produced on a
burning 747 that have nothing to do with depleted uranium, right?
Like burning plastic, foam, wire insulation, paint...
that are much the same as the guys
who helped on 9/11 and helped clean it up (when 2 DU counter weights burned 100%).
DU in the 9/11 cleanup? First I've heard of it. Googling <depleted
uranium new york 9/11> brings up a bunch of bizarre theories.
Oh, here's a(n in)credible source:
http://www.americanfreepress.net/html/depleted_uranium.html
It says 1,500 Kg of DU counterweights were used in 747 wings, and
speculates such were involved in 9/11. Alas, the planes that struck
in New York were 767s.
An inconvenient quote:
" ' Boeing has never used DU on either the 757 or the 767,
and we no longer use it on the 747,' Leslie M. Nichols,
product spokesperson for Boeing's 767, told AFP.
'Sometime ago, we switched to tungsten, because it is
heavier, more readily available and more cost effective.' "
Tungsten, okay, but heavier than uranium? Hmm, it seems it actually
is: 19.25 g/cm^3 vs. 19.1g/cm^3 for uranium.
Some research has been done, there are papers on that, that it is dangerous.
If it was to be used in cars sure enough it would pulverise in some cases,
get into the environment, get burned, there you go.
It's a heavy metal, and likely not very nice on that account, but it
doesn't sound especially nasty:
http://en.wikipedia.org/wiki/Uranium#Characteristics
http://en.wikipedia.org/wiki/Uranium#Precautions
I wonder how it compares with, for example, burning iron. Iron
overdose from vitamins is, AIUI, a--if not the--leading cause of
poisoning deaths in US children.
The (very) sad thing with US is that it is so much market driven that many safety issues
are ignored.
nano materials.
genetic manipulated foods.
Now for example it is found that the genetic manipulated crop, that produces some poison to
kill bugs, _also_ kills bees.
No bees no crop.
Very clever.
Not ignored, discovered. If you're the first to do something, you're
also often the first to discover it wasn't a good idea!
Best regards,
James Arthur
