Rich Grise, but drunk
Our approach many years ago was simply to glue fake naugehyde onto plain
old aluminum.
"Fake" "naug[a]hyde?" I thought naugahyde was already fake! ;-P
Cheers!
Rich
old aluminum.
Hello Don,
It depends. The ads look nice but upon further inquiry things can get
out of hand quickly when mods are required.
I always wondered where the naugas are grazing ;-)
They've taken up residence with families:
http://www.naugahyde.com/promoitems_nauga.html
No, you can't, not even a Schottky. That would require dropping the uC
clock too much to allow for a deep enough battery depletion. The usual
tricks are to split up VCC and run 'naturally protected stuff' such as
LED directly so the heavy current hitters are taken care of. The
(hopefully low current) remainder gets the resistor and diode to GND
treatment. This will deplete a battery when it's left in the wrong way
but that's a small price compared to a fried unit. As long as nothing
gets hot and the electronics can stomach the reverse that the diode
allows. Fuses are usually a no-go because that's nowadays considered a
field failure by the discerning consumer.
I guess I should pause before typing, sigh. Of course, I meant "use
a bridge rectifier" on the input so the device works no matter which way
it's plugged in, when you have the supply voltage to spare.
Interesting. I'd pretty much guessed about the LED's, but I wasn't sure
what you did for a uC or other ic's.
Joerg said:Hello NT,
Square ones are usually a little more in cost. But not a lot so this is
certainly an option.
For this app it would be better if they are spread apart a bit so that
the lettering next to them could be large font, for people with not so
good vision. It will be used by people with and without their reading
glasses on but the unit will be close by. A short row of adjacent LED
can be a challenge for folks that need reading glasses and I am pretty
much on the way to become one of those myself ;-)
Regards, Joerg
Joerg said:One fact that is often overlooked is the temptation of consumers to plop
NiMH or NiCd in there instead of alkaline AA cells. Those can pack an
incredible punch and some are able to sink well over an amp into
anything that gets in the way, causing undesired pyrotechnical effects.
Regards, Joerg
Regards, Joerg
1A? NiCds can kick out 60A for short periods. Ask the r/c modellers.
I think you want the world, and you want it cheap!
In the UK at least, there is an intermediate 'form' of injection moulding
available. With this, the dies are made of much lower quality material,
with a life expectancy of only about 2K+ pieces. They are made using a
fairly simple CNC process, and the tooling costs are perhaps 1/100th that
of a normal injection moulding process.
