Carl Ijames
This is the third or fourth post of Rich's that used "punch" for
I had a die made by http://www.acesteelruledies.com/ for work and was
very pleased. Roughly 3"x11" rectangle with 16 holes about 1" in
diameter, laser cut into hardwood with steel rules for about $100, in
about a week after I emailed them an Autocad drawing. This is to punch
foam rubber but it should work on thin acrylic or petg or ABS or ...
Call them; they were very helpful on the phone. Oh, if you send them
the material they will even do the punching for you if you don't happen
to have a press
. That was $2.50 a piece for 50 pieces, and I'm sure
that would get better with more volume but that was all the gaskets I
needed for now and I was really tired of hand punching them
Punching is always cheaper than drilling, even one hole at a time.
"drill". It took that long to seep through my poor slow brain:
If you start with an enclosure with the right materials and design,
and plan on putting a stick-on top panel then you can have the holes
punched in one operation with a custom die. A set of dies with round
holes should be relatively cheap. If you punch toward the inside of
the box the holes can even be a bit ratty as long as they're clean on
top (or at least ugly but concave) where you need to stick on the
label. You could even have a few oblong holes (like for the ribbon
cable from the panel) at a bit higher cost for the die.
to have a press
