Rich said:
If you use aluminum or FR-4 for a recessed front panel, they can be
punched for pennies, please forgive the alliteration.
And with SMT stuff, you might not even need it punched, except maybe
the plated-through holes. I don't know if typical vias are drilled
or punched.
Cheers!
Rich
This is the third or fourth post of Rich's that used "punch" for
"drill". It took that long to seep through my poor slow brain:
If you start with an enclosure with the right materials and design, and
plan on putting a stick-on top panel then you can have the holes punched
in one operation with a custom die. A set of dies with round holes
should be relatively cheap. If you punch toward the inside of the box
the holes can even be a bit ratty as long as they're clean on top (or at
least ugly but concave) where you need to stick on the label. You could
even have a few oblong holes (like for the ribbon cable from the panel)
at a bit higher cost for the die.
I'd inquire at your local tool-and-die maker, or perhaps several. Some
_will_ turn you away; you need the capable one with an open mind who
wants to listen and do business. If you can't find anyone local then
try rec.crafts.metalworking -- some of those guys run shops. If that
doesn't work then email me: I know a shop that used to be really into
that sort of innovation until the owner died. They may still be but its
one of my dad's contacts so its been a while since I've heard from them.
You may even be able to do a proof run in the states then ship the dies
overseas for the production work.
Another thought is an enclosure that takes end panels -- as Rich said
having a bunch of aluminum front and rear panels stomped out on an NC
machine should be pretty cheap.
