ring_theory
Mankind transforms energy from it's various forms to kinetic for the work.
I ultimately believe that we just havn't found the correct method of
transformation to be fully effective at producing renewable energy.
This is mostly because mankind has through the years taught our students
that the laws of thermodynamics under no condition can be broken. Which I
agree. But on the other hand they fully ignore the fact that the laws can be
upheld.
I feel man has come to this conclusion by observations based
on the wrong combination of transformations and using the work
(kinetic energy) prematurely.
Some of the combinations mankind uses:
transformations failure
______________________________
Fuel-kinetic Uses up fuel
hydro-elec-kinetic Not a closed system
solor-elec-kinetic Not a closed system
wind-elec-kinetic Not a closed system
neuclear-elec-kinetic Not a closed system
However there is hope for mankind yet. all you have to do is listen to me
closely.
ELEC TO KINETIC TO ELEC TO KINETIC, ECCENTRIC FOR INFINITY!!
Where do we get the work from you might ask. the work comes from the
"kinetic to elec" transformation where it is effortlessly drawn from the
system via electromagnetic induction. Elec can be used for the work in most
cases. However the added appliance is inducted to the system remaining a
closed system.
I invented a device that's sole pourpose was to transfom energy
indefinitely.
I initially pondered how we could move a perminant magnet flux field through
a induction coil infinite. It took nearly 20 years but i have perfected the
method of doing it. Creating the closed system that man has only dreamed
about till now.
It is simply a rotary transformer.
Thermodynamics and overcoming general consensus that there is no way to win
the game.
If were concidering it a game it is important that we know the rules/laws of
the game. all the rules are referring to a "closed system" To date mankind
hasn't created a closed system. So were not even in the game. We can't even
begin to play we make one transformation and greedily use the energy for the
work. However the game punishes us via heat. "end game".
However man hasn't met the qualifiers of the second law of thermodynamics.
Most often the first and second laws of thermodynamics are discussed however
there is 2 more laws related to thermodynamics. that we can't even begin to
explore as we aren't even in the game at this point.
Third law of thermodynamics
For changes involving only perfect crystalline solids at absolute zero, the
change of the total entropy is zero.
Zero or rather the result = 0. Is true unity. which mankind hasn't achieved
yet.
However it is possible via kinetic energy in a closed system bieng a
constant
providing the right form is used and that form is the ring. If I'm correct a
rare earth magnet is a crystalline solid. That's what the core is made of in
my rotary transformer.
Zeroth law of thermodynamics
If two bodies are each in thermal equilibrium with a third body, then all
three bodies are in thermal equilibrium with each other.
Many things come in 3's. My transformer has 3 functional transformations via
3 main componants. The first (drive) componant is the only componant that
will produce heat on initial startup till the core gets up to speed than it
will reach an equilibrium rotating the core, and will require very little
energy to maintain it's rotation achieving the thermal equilibrium once at
operating rotation. the third body is the induction and last transformation.
Theory or not it is an observation i have made through conception, research
and developement of the next generation transformer.
This device is the device that is going to get mankind in the game and solve
the energy crisis. It is the renewable energy that has been so elusive till
now.
However I need help in developing this highly innovative technology.
I have an highly innovative invention that I would be willing to give
research rights to any US research facility excluding alaska, hawaii,
(unless your paying for the flight there and housing and transportation once
I get there) that would be willing to dedicate $100,000 and a years worth
of research and developement at their facilities. I didn't say give *me*
$100,000 the money would be for the componants and controlled by the
research facility. I'm not concerned with money at this point, but I am
concerned that this innovative technology gets some real research time at
proper research facilities. My wealth is going to come once the technology
is released as I'm not giving up rights and royalties of the device. However
I would be willing to share the profits with that US research facility that
steps up and is willing to take a chance.
The first form of research would be to create a computer model of the
functionality of the device. to confirm that it will work before proceding
to the manufacturing of the device. I'm not capable of inputing the required
peramiters for the software so I do need to confer with qualified
professionals on the specifics of the device.
Ring
upheld.
closely.
closed system.
indefinitely.
about till now.
the game.
yet.
constant
now.
Ring
