Lost? I was thrown somewhere between Narnia and a bad acid trip when I received the following reply to my question regarding potential energy of a one tonne mass suspended 3 meters above the Earth's surface.
I rounded the value to 0.002 kWh which = 2Wh. Trying to visualize and understand the work required to raise a tonne 3 meters can be accomplished by providing a constant power flow of 2 watts for an hour, was starting to caramelize my onion. Couldn't see it. Converted value to Ws. 2Wh = 7,200Ws. Oh, 7,200 watts is a considerable amount of power, but raising a tonne 9ft in one second? Naw, still couldn't see it. I had to be missing something. Was this calc based on 0J point being the center of the Earth? Were forces such as the centripetal force that the Earth exerts on the sun in play here? I was thinking what Harold mentioned earlier, that even if the mass base unit is the kg, to be used per SI standards, that doesn't magically change 1,000,000g into 1000g, even if 1Mg is entered as 1000g, as is expected when using SI. I had to conclude that the person who provided this result was not proficient using SI units. A little later in another post reply, the definition of a kWh was stated as 1000 watts delivered in an hour. Not written as 1000 watts continuously delivered for an hour but 1000 watts in an hour. My confidence in this particular forum was waning. So, I have concluded that PE is derived using the formula PE = mgh. Plugging my values in it reads 1000kg X 9.8 X 3m = 29,400,000J. 29,400,000 / 3,600,000 = 8.17kWh. I'm going to run with that value. My goal is to recover those 8kWh for consumption. The energy transition from falling object to mechanical motion will exceed 90% efficiency, in theory, where as mechanical to electric energy can hopefully be achieved with 50% or above efficiency. If I can reach those values, 4kWh will meet my nominal daily power usage. That operates computer, security cameras, loudspeakers, lights. During summer months when running a/c unit, my usage approximately doubles. I appreciate your comments and assistance with my quandaries.
