Martin Riddle
Bill voted down...
<http://politics.blogs.foxnews.com/2011/07/12/house-turns-out-lights-bulb-ban>
Cheers
Cheers
The 4 Watt bulb has been burning for over 100 years.Bill voted down...
Cheers
It has a world record for it. Carbon filament.
http://www.centennialbulb.org/
Is there a failure of comprehension here? The measure, H.R. 2417,
Better Use of Light Bulbs Act, which would have repealed those
provisions of the Energy Independence and Security Act of 2007 which
federally ban the manufacture and sale of certain light bulbs,
*failed* to pass in the house. So the 100W bulb is scheduled for
extinction.
Bill,I see Home Depot is selling 60 watt LED floodlights that only consume
maybe 10 watts. They had one on display next to an incandescent, and
it was hard to tell the difference except for the heat. Still pricey
though at $47.
-Bill
So, as the usual consequence of imperial edicts, the "little" guy whoBill said:I see Home Depot is selling 60 watt LED floodlights that only consume
though at $47.
But a decent 100W incandescent is 1620 lumens, not 1185, as I pointed out.
Even believing the CFL specs--which probably apply to the first 100
bulbs the factory sends back over here for QA, and never
thereafter--you'd need 31W of CFL to get there--suddenly the power
saving isn't 6x but 3x. But there's more: CFLs don't have the same
surface brightness as bright incandescents, so a CFL that big won't fit
the harps of most lamps.
I use CFLs too, but I think they stink. My work lamps are all Luxo 22W
cool white circline fluorescent + 100W tungsten.
Waiting around for the CFLs to turn on in the bathroom, or in the front
porch light fixture (where they're about as bright as a Christmas bulb
in cold weather) doesn't excite me at all.
Cheers
Phil Hobbs
CFLs are rated in Marketing Lumens (TM), which are rather like Fisherman
Pounds, and for the same reason.
Anyone who thinks that a cheap 'n' nasty 15W CFL is the equivalent of a
normal 1620 lumen, 750 hour, 100W incandescent hasn't looked very hard.
I'm aiming to collect a few hundred 100W bulbs before they go away.
What a pain in the tuchis.
Yes, you are right, but I see 1 watt LEDs on ebay for around $1 each,
so you could make a 10 watt unit (60 watt equivalent) for maybe $10
plus time to do it.
Then you know something UL doesn't....go ahead and put the
incandescent in a cellulose packed ceiling and see what happens-
that's one way to test the fire retardence.
every "100W equivalent" CFL I've seen consumes around 23W.
A "75W equivalent" CFL is around 18W.
BTW,if you buy 130V "contractor" bulbs,they last even longer.
Or put them on a dimmer,slightly dimmed,and they last longer.
bulbs the factory sends back over here for QA, and never thereafter--
you'd need 31W of CFL to get there--suddenly the power saving isn't 6x
but 3x.
But there's more: CFLs don't have the same surface brightness as bright
incandescents, so a CFL that big won't fit the harps of most lamps.
Wal-Mart & Dollar Tree have a good price on 4-packs.
CFL circuit boards *are* known to burn, no kindling needed.
I have heard of a small number of fires and seen some nasty spectacular
failures of dollar store CFLs, usually with no claim of UL listing at all,
let alone questionable.
What I am talking about is the outright stool specimens that I see in
most dollar stores other than Dollar Tree. The one I saw at Dollar Tree
looks to me more like a "mainstream quality" CFL.
The stool specimens are of "brands" that I see mainly in dollar stores
other than Dollar Tree, including a brandless one or two. In my
experience, they have a few issues:
* Light output always less than that of other CFLs with same claim
* Color is often cool-daylight color
* Some said to be "warm white" are cool-daylight
* Most "warm color" ones have rotten color rendering like that of
"old tech warm white" (whose CRI is 53)
Back to CFLs with honest UL listing, of major brands and/or sold by
major retailers: Their circuit boards are made of a UL-recognized
flame-resistant material, and their ballast housings are made of a UL-
recognized grade of flame-retardant plastic.
UL 1598
http://database.ul.com/cgi-bin/XYV/...n=versionless&parent_id=1073988069&sequence=1
TYPE IC LUMINAIRE — Luminaires marked "TYPE IC" may be installed such
that insulation and other combustible materials are in contact with,
and over the top of, the luminaire.
Wow, they are so obviously superior, there will be no need for a law
eliminating the hapless competition.- Hide quoted text -
- Show quoted text -
