me
I have seen them. A generic HPGL driver should do. What interface
though, GPIB is getting rare now.
It uses a serial interface.
Then steel wool roughen the Kapton side instead.
The fuser roll is hot enough to get a sheet of paper up to
toner melting temperature, but not hot enough to get this
stack that hot. I suggest you try with the copper preheated
a bit. You don't want it hot enough to melt the toner on to
the photo sensitive drum, but just warm. A few degrees can
make a big difference. Toner has a pretty sharp melting
temperature.
Foil printer??? I gotta Google that..
Is that what's printing on beer cans??![]()
James Arthur said:Some guys on the Yahoo group use hairdryers to "reflow" the toner
prior to etch.
I measured some toner melting points. The original HP toner in my
LaserJet 6L melted (flowed well enough to be smeared with a hot iron)
somewhere between 99 deg. C and 106 deg. C, and toner I used in a
refill cartridge melted between 98 and 101 deg. C.
Interesting project, D from BC.
James Arthur
Perhaps you're thinking of a heat gun? Hair dryers only get to about
120F, way to low to melt toner. Heat guns get up to 1000F.
D said:Success!!!
This photo is after chemical wash and etching.
http://www.members.shaw.ca/chainsaw/SED/P1010019.JPG
It's a 6 step process..
I haven't cleaned the residue off the copper yet.. It gets cleaned
just before soldering.
The "D from BC" font has 4 mil line width!!! It's only dirty from the
residue and there's no breaks in the copper.
However, there's defects at the bottom of the PCB.
Apologies for lack of electronics design in this post...
Often I can handle the electronics. It's everything else that I get
stuck on.
D from BC
That looks pretty good. You should refine the process some more, great
looking boards are the target. It should be within reach.
