I'd like to find a replacement for this relay:
The markings on the relay are:
80B43249S01
611-1217HQ
CDE 24VDC
MEXICO
718
Using a digital caliper, the outside measurements of the relay (not including the pins) are:
W: 30.64 mm
D: 18.90 mm
H: 29.39 mm
The relay has five pins on the bottom, only four of which were soldered. In the image above showing the pins, it's the upper-right pin that wasn't soldered.
This relay and a second identical relay are from a Whirlpool oven / microwave combo unit, built around 1986. One of these relays was used to activate the fan while the microwave was running and the other was used to activate the magnetron. Both relays are now sticking (one in the "on" position and the other in the "off" position) and need to be replaced.
Any information or resources for finding a suitable replacement part would be appreciated!
80B43249S01
611-1217HQ
CDE 24VDC
MEXICO
718
W: 30.64 mm
D: 18.90 mm
H: 29.39 mm
