daestrom
krw said:No, the meter measures *power*. As others have been trying to tell
you, the torque (hence RPM) of the disk is proportional to the current
times the voltage in the respective coils. No "calculating" at all
and *certainly* there is no power factor calculated or measured.
I disagree. Analog computers were around long before digital (the
speedometer in a vintage car is an obvious one).
The three coils create a torque on the disk proportional to real power.
The arrangement of the coils and inductance of the voltage sensing
coil are such that the power factor *is* implicit in the development of
the torque. A load current that is 90 degrees out of phase with the
applied voltage results in no torque developed. (which is why many
claims that 'power factor correction' will save you big money, are bogus)
If that were the only torque applied to the disk, it would spin rather
rapidly because the mechanical friction is pretty small. And it would
be hard to calibrate since the torque needed to drive all the gearing is
somewhat variable. So another permanent magnet called a "drag magnet"
is positioned next to the disk creates a counter-torque that is
proportional to the disk's speed. Obviously the disk stops
accelerating/decelerating when the torque produced by the sensing coils,
friction and the drag magnet balance. The result is that the disk speed
is proportional to the power in the sensing circuits.
(As an aside, some criminals have tried to cheat the power company by
positioning additional 'drag magnets' above/below the disk. This tends
to increase the counter-torque developed when the disk is in motion,
slowing the speed of the disk for a given power level. The law does
provide sanctions for such meter tampering.)
All the gears and wheels form an integrator (as in 'calculates the
integral of the disk speed with respect to time'). Because the disk
speed is 'revolutions / time', counting the revolutions is the calculus
operation of integration with respect to time.
It's a meter that calculates the energy usage by sensing voltage,
current and the phase relationship between them (i.e. power factor) and
integrating the results over time.
daestrom
