Bob Myers
Floyd L. Davidson said:You don't appear to understand that the limited set of values makes
it digital, by definition. PERIOD.
More argument from authority. Yawn.
Bob M.
It is in fact! It's a digital PAM signal. Indeed, v.90 modems
make use of it.
However, just as you can convert an analog signal to digital, you
can indeed convert digital to analog. One method is to produce a
digital PAM signal and run it through an analog channel.
Arny Krueger wrote:
Scope? SCOPE? isn't that an analog device? True digital work is don with
pencil, paper, and calculator. Theory rules!
Jerry
Floyd L. Davidson said:That is, since you seem unable to grasp or investigate
it, the web site of the National Telecommunications and
Information Administration, a part of the US Federal
Department of Commerce, in Boulder Colorado. Which is
to say they are next door to and under that same
management as the NIST (the National Institute of
Standards and Technology), and NOAA (National Oceanic
and Atmospheric Administration) which you may also have
heard of...
Or, to put it another way, you will not find anywhere in
the world a valid definition that disagrees with that
one. If yours is not in agreement, you are *wrong*.
Logically you are walking the plank. Such technical
definitions have nothing to do with logic.
It is an
arbitrary decision that it means this or it means that.
If we all agree on the arbitrary decision then we have a
standard, and we can use it knowing that others will
understand what it means.
And you, like Arny, probably have no idea what you'd
see on a decent scope anyway.
I'd like Arny to explain how he can look at a scope and
tell if a single cycle of a sine wave is an analog signal
representing one cylce of a pure tone, or is just a digital
signal that represents 8000 different bytes of data from
a digital image.
You just digitized it. You can no longer have a value of 0.15 volts.
No. By definition it is not. With an analogue signal you have
(technically) an infinite number of values between an input of
0.1 and 0.2. With digital you do not.
Digital doesn't mean numbers, it means discrete values.
What you need to get straight is that it is not *my*
definition. It is the *standard* technical definition
recognized by virtually *every* standards organization.
That is a logical fallacy on your part. An "argument
from authority" has great weight if it is valid. To
be valid it must pass three tests:
1) The authority cited must actually be an authority.
2) All authorities must agree on the topic.
3) The authority cannot be misquoted, taken out of
context, or be joking.
Clearly citing the NTIA and MilStd definition is indeed
a *very* strong appeal to authority, and no mere opinion
can even come close to invalidating it.
You know one way to be absolutely positive that your
logic is not good is to do a reality check and find that
the answer you have is wrong. It this case that is very
easy to do, which is why *standard* definitions are
quoted from authoritative sources. If you disagree,
then clearly you *don't* have the logic right!
So cite even one such valid reference! (You *cannot*,
because there are none.)
(And recognize that if you think you have one, then
there is one of two things clearly true: Either 1) you
do not understand that the other definition is not
actually different, or 2) your reference is not a valid
one.)
You are not a valid reference. You don't even come
close to being equal to the NTIA.
Floyd L. Davidson said:Floating point is analog, integer is digital.
Floyd L. Davidson said:You can repeat that all you like, but you are wrong
every time you do.
By *definition* it is a digital signal.
quantization:
A process in which the continuous range of values
of an analog signal is sampled and divided into
nonoverlapping (but not necessarily equal)
subranges, and a discrete, unique value is assigned
to each subrange.
If you do not stay with standard definitions it is
impossible to discuss anything rationally.
No matter how dense you want to be about it, that
government "expert" happens to be right. And you cannot
find *any* expert that will disagree.
That is the
*standard* definition, and virtually *everyone* agrees
that it is correct.
Yes. I've got the specs right here! Literally, I have
had a graph on my web site for several years now that I drew up
to illustrate something I wrote once upon a time
http://www.apaflo.com/floyd_davidson/t1pulse.jpg
Floyd L. Davidson said:(Again, that is
the nature of arbitrary definitions, this time of what
"encode" and "modulate" mean.)
Floyd L. Davidson said:Your opinion of standard definitions is worthless.
Again, not really true. Quantized is necessarily
digitized.
Floyd L. Davidson said:Look up the definition of "quantization" again. It simply
makes no difference. If an analog signal is quantized, the
result is a digital signal. That is by definition, and you
cannot escape that with mumbo-jumbo and faulty logic.
Floyd L. Davidson said:No, in fact it is not. Electrons do not necessarily all move
at the same speed...
Floyd said:And you, like Arny, probably have no idea what you'd
a digital image.
Floyd said:If you don't understand what they said, you probably do
have a bridge that somebody sold you...
Don said:Since I see no smiley face to let us know you are jesting, I have to believe
you really mean it. In which case I have to believe you aren't as bright as
you were sounding. A final test of applied theory is..... Does it work as
intended? Where's my scope?
Arny Krueger said:(1) A decent scope gives a pretty close approximation of what theory
predicts.
(2) I was probably working with decent scopes before you were born.
I've seen both kinds of data many times. Imaging data almost never looks
like sine waves.
