You have cited a source that is describing something else. It is a
Bullshit Don, that is abjectly stupid to claim.
source that you claim is authoritative and impeccable. Kindly go and
read what it has to say on the Nyquist rate and come back and repeat
that claim without blushing. Actually I'm betting you won't blush
because you won't understand the problem.
Nyquist rate:
The reciprocal of the Nyquist interval, i.e., the
minimum theoretical sampling rate that fully
describes a given signal, i.e., enables its
faithful reconstruction from the samples. Note:
The actual sampling rate required to reconstruct
the original signal will be somewhat higher than
the Nyquist rate, because of quantization errors
introduced by the sampling process.
Apparently *you* don't understand it. What they say is
correct. If you think otherwise, be my guest...
I am the credible source, because I know what I am talking about.
You are not even close to being a credible source Don.
And not that you cannot find *anyone* who is credible that
agrees with you.
But clearly you are right in your appeal to authority. Tell you what I
will do. I will examine some analogue audio waveforms today to see if
I can find any parts of them that are in fact digital. They will be
easy to recognise because there will be brief moments where they are
flat. That will make them digital by your definition.
How do you figure that?
And perhaps I will look at the digital signal recovered by my DAB
radio. That is band limited and contains no flat bits and steps at all
- in fact it looks a bit like a bendy almost-sine wave. That'll be
analogue by your definition.
Don, you have made it abundantly clear that you don't
understand this topic at all.
