Floyd L. Davidson said:
It wasn't analog until you ran it through an analog amplifier.
More nonsense.
Again, the ONLY definitions of "analog" and "digital"
which make any sense treat these as distinctions in
the form of information encoding being used. If I
run EITHER a "digital" or "analog" signal through an
amplifier, what comes out can still be interpreted (the
information recovered from the signal) ONLY if the
encoding intent is understood and the proper decoding
applied.
A serial stream of digital data still makes sense, whether
the amplitude assigned to the "1" or "true" state is
0.1V, 1V, 10V, or 100 kV. But it makes sense
ONLY when interpreted AS a serial stream of bits.
Similarly, an analog representation of, say, video makes
sense only if interpreted AS "analog". No matter how
"digital-ish" it might look, if you try to interpret THIS
signal as a "digital" stream, you'll get gibberish.
Floyd, you would be well advised to stop treating your
"definitions" as though they were somehow handed
down by God, and instead try to employ arguments
that are actually based in something sensible.
The NTIA is an authority, and MilStd specifications are
also authoritative. That is the reason I cited them.
And the *fact* is that you have not and cannot cite any
authoritative standards body that does not agree with
them.
Neither of these - and for that matter, NO standards body
- is an Infallible Source of Absolute Truth, and no standard
should be looked at as a substitute for good ol' basic
theory and experimentation. This is the fundamental flaw
with any argument "from authority": wrong is wrong, no matter
who writes it down on a piece of paper. God knows I've
spent way more than enough time in my career working
with various standards organizations (in fact, I am currently
chairing one fairly well-known such group), including both
"industry" and "government" efforts, and I can tell you from
long and painful experience that simply because something
appears in a standards document does not make it correct.
With the right people paying close attention, these documents
can often turn out pretty darn good - but they should NEVER
EVER be used as a substitute for some actual thought and
understanding of the subject matter at hand.
Bob M.
