Scott Seidman
Really? Then I shouldn't be able to find any standards
organizations which use a conflicting definition, right?
The nicest thing about standards is that there are so many from which to
choose.
Bob Myers said:Nonsense. You don't believe it is possible to sample
an "analog" signal and have it remain analog?
Well, THAT certainly makes it clearer....
Since you seem to be so hung up on definitions, Floyd,
try this one on for size:
Continuous: unchanged or uninterrupted: continuing
without changing, stopping, or being interrupted in space
or time.
Note that this does not say anything at all about the range
of possible values being "continuous" (which is what you
seem to be trying to say in the above).
Arny Krueger said:I aced "Signals And Systems Analysis" and placed high in "Linear Stochastic
Optimal Control" - probably the heaviest signals trips I ever took.
Bob Myers said:Really?
Suppose I show you an oscilloscope screen which
is displaying a single line of video, which happens to be
carrying an 8-level gray-scale pattern. It clearly shows
a set of discrete levels.
Further, since this video happened
to be created by a D/A converter with only three bits at
the input (our video generator was built on the cheap!), those
are the ONLY levels this signal may exhibit. Is this a
"digital" signal?
Ah, Floyd - argument from authority again, huh?
Arny Krueger said:Well it shows what was once a set of discrete levels. Since it is now in the
analog domain, there will be rise time, overshoot, tilt, simple inaccuracy,
and etc. .
It's an analog signal that represents something that was once quantized.
The definitions are fine, it is the misapplication of them that sticks.
Floyd said:Sheesh! That *is*, by definition a digital signal.
Floyd L. Davidson said:Apparenlty Claude Shannon didn't agree with you on that.
That doesn't make it quantised.
Whether or not a signal is "digital" depends upon what you intend to do
with it. A PCM signal conveying the digits 01010101... is digital; a
square wave generated within an audio synthesiser isn't, even if the
signals are identical.
Radium said:That's what I was talking about. Reducing the temporal frequency of
the video w/out low-pass filtering or increasing the length of the
movie.
Arny Krueger said:Nope, the phase shift is appreciable down to Fc/10. Ever hear of Bode plots?
Most digital audio is brick walled at 0.95 * Fs/2 or about 21 KHz. Most
power amps are pretty flat up to about 50 KHz.
For people who don't already know?
Well, by the brick wall filter which is usually set as stated above.
DACs can't alias. Only ADCs can alias. Improperly filtered DACs may produce
images.
The input side of a digital system is called an ADC, not a DAC as you just
said.
Claude Shannon proved it mathematically in the late
1940's.
You are free to dispute Shannon...
Radium said:Actually I don't want other parts to be unchanged. What I would like
is the temporal frequencies [of all parts of the video] to be
decreased but without decreasing the speed of the video signal.
Floyd L. Davidson said:Floating point is analog, integer is digital.
Phase may not affect your ears much, but it does affect
the data. It has nothing to do with flat tops and
vertical edges, which seem to be something you can't get
around.
My point is that there is a lot more to a practical
amplifier than just simple gain. Sorry that you missed
the point, again.
Floyd L. Davidson said:True. Theory predicts that you cannot look at a scope
and tell what kind of information, digital or analog, is
carried by a signal. So one wonders why you want to talk
about scopes.
Nobody made a "decent" scope for several years after I
was born.
Bringing up the distraction of looking at such signals
with a scope clearly indicates that you do not
understand it. You *cannot* distinguish between digital
and analog signals with a scope.
(See below, for a very good example of why that is true.)
It *commonly* does. Every time anyone fires up a v.90
modem and downloads *anything*, the waveform on the
signal from the telco to the subscriber's v.90 modem
looks like sine waves.
That is true whether it is
imaging data, text, voice, or whatever else you can
think of.
But in fact those "sine waves" are as much as 8000 bytes
per second digital signaling.
And if you put your scope on the line and look at them,
and then hang up the phone and make a voice call, you
will not be able to see *any* difference between the
analog voice signal and the v.90 protocol digital
signal!
The reason is because there absolutely is no difference
at all. Both signals are generated in exactly the same
way by the exact same CODEC in the line card at the
telco. They necessarily will look identical on a scope.
Don Bowey said:At this point I need to say "who cares how it was generated?" It sure
won't
need to be passed through any analog channel to make it analog. It is
analog by the time it gets off the board that generating it.
And of course you had no idea until now that that is
what we've always been talking about, right?
Scott Seidman said:The nicest thing about standards is that there are so many from which to
choose.
"Appreciable" is not specific...
The point is that in
practical applications there are few effects at Fc/2
which are unreasonable.
For example... A typical voice channel provided by the
telecommunications industry is often stated as a 4Khz
wide channel. In fact of course it is not. The lower
limit is determined by high pass filters designed to
reduce 60Hz power line interference. Cutoff filters are
usually at about 80 Hz for that. The high end is
limited in digital systems by the need to avoid aliasing
of frequencies above 4000Hz, so the LP filters generally
have a cutoff between 3750 and 3850. Essentially that
provides a 80-3750Hz channel, maximu.
The industry only guarantees that they will provide
400-2800 Hz of bandwith over the Public Switched
Telephone Network. Much of the reason for that is
that phase shifts and envelop delay at frequencies
from 3000 to 3750 are sometimes (but not always) high
enough to be a problem (which would require special
conditioning to correct for).
You are saying the effects are "appreciable" down to
375 Hz, which means the _entire_ 400-2800Hz bandwidth
is suffers "appreciable" effects.
It can be measured, but it does *not* cause appreciable
effects.
So, as I've stated... your example shows that the
filters are placed at 0.95 times the maximum possible
frequency that can traverse the channel. And those
filters are on the *input* to the channel.
The fact that the power amp, the last part active of the
system, actually has a greater bandwidth (even then,
only 2x), is insignificant.
What about the bandwidth of
the output stages of the D to A converter...
That is
where it makes the most difference in regard to
conversion of digital to quasi-analog to analog without
appreciable artifacts.
Wrong.
But secondarily, the speakers
are also an important part of the overall channel... and
ultimately the point at which a digital signal is
absolutely converted to analog (perhaps artifacts and all).
You said it was simple. Apparently you should read up
on the topic.
The brick wall filtering is on the channel *input*, to
prevent aliasing. It does not limit what could show up
on the output, as if it were not there the frequencies
that it removes would be folded at the output anyway.
The absolute upper limit (at which point it generates
100 percent distortion) is Fs/2, for input bandwidth.
Okay... if you want to limit this to separating the ADC
from the DAC, the DAC doesn't have the brick wall
filter, the ADC does.
How do you get an image out of a DAC, if it wasn't
produced at the ADC?
Improperly filtered channel output might have artifacts
from the sampling though, but no HP output filtering is
necessary to remove any signal resulting from the input
signal.
Semi-gibberish.
They are both part of a "digital channel", and *that* is
what I am talking about.
Nothing else makes sense in this context.
Floyd L. Davidson said:That has no relevance to whether it represents a discrete set
of values.
It could also be a digital signal. You simply cannot
tell from looking at a scope.
Oh, are we back to the idea that the NTIA had never heard of
PCM when they came up with those definitions?
