News
vaughn said:I get it!
You didn't.
On thing is clear anything for the USA is negative towards to compressed
air
as the US corporations are doing other things.
Motorists, however, have come to expect much more from their cars. That's
why some of MDI's critics think that automakers should be focusing not on
air-powered cars but on pneumatic-fuel hybrids. Unlike cars running on
compressed air alone, the greater power available from pneumatic hybrids
would suit full-function, highway-capable vehicles. ...
The spare-no-expense submarines themselves
ran on batteries submerged and Diesels on the
surface.
I work in R&D on alternative energy projects,
and also tinker with them at home, thus my
well-developed BS filter to avoid loser projects
and scatterbrained inventors. I'm only interested
if they focus on analyzing and solving the remaining
problems
Big corporations have learned through
long and expensive experience
what sells and what doesn't,
Very few people will put up with any
significant inconvenience to save
energy,
The world progressed by individual men or small groups of them, not by
money
obsessed corporations.
The best and most innovative and receptive to new ideas were the small
companies. They appreciate those who thought out of the box.
Sure, but you're so far out of the box you'd need a Stargate if you
wanted to see it.
I have done R&D for the EU working for a small company. Also working for a
corporation. Also for a smallish US company developing its own products.
Size matters as the company culture is very different.
GillesQT said:University of Connecticut -
Quasiturbine in « Brash Vehicle Propulsion System ».
Photo and video:
http://www.brashengines.com/FAQ.html
http://www.youtube.com/brashengines
A project supported by the US Department of Transportation
(John Volpe National Transportation Systems Center)
exploring the use of BRASHT technology for large vehicles, such as mass
transit vehicles.
Jim Wilkins said:The Titanic had an energy-recovering turbine that ran on the nearly
atmospheric pressure exhaust steam of the two main triple-expansion
engines and generated about as much power as one of them.
http://www.titanic-titanic.com/titanic_engine_room.shtml
Steam expanded in the turbine from 9 PSI (gage?) to almost a vacuum in
the condenser, the exact value depending on ocean water temperature.
Other ships had them too but Titanic has more references.
News said:< snip >
The opening post had the compact and efficient Quasiturbine running on
steam. What its efficiency is on steam is I don't know. But the engine is
rotary and small. The cyclone part of this engine coupled to a
Quasiturbine looks interesting. If a good efficient match then maybe
something that is viable and marketable soon could be produced.
Would having these small Quasiturbine engines
in series, the steam output of
one fed into another, increase efficiency?
They are very small which is great advantage in packaging, as well as no
pistons giving a smoother operation.
That scam has been around for how long now? Yes, it does "work" if by
that you mean 'runs'. Produce useable power and good fuel economy it
doesn't...unless it has been greatly improved since I last saw a video
of it in use on a chainsaw. At that time I could have cut the same
wood with a dull handsaw faster.
No, I am not going to try to download another idiot video on dial-up.
Harry K
...For cogen I
would like the steam Cyclone/Quasiturbine, as the condenser can be used to
fan heat into a house.
Are you prepared to maintain and repair it? Ever rebuild a carburetor,
starter or wiper motor? If not then experimental alternate energy will
be a money pit for you.
I am talking about a production model.
Jim Wilkins said:I have had to make repair parts for production models of my chainsaw,
string trimmer, Sears lawn tractor, Ford truck, Maytag washer, etc
when the manufacturer no longer supports them, like after ten years.
Earlier this week I was machining little brass carburetor parts I
couldn't buy, to replace broken plastic ones. Here's a steering sector
gear Sears no longer sells:
http://picasaweb.google.com/KB1DAL/HomeMadeMachines#5285710360947850418
News said:My point is that the cyclone/Quasiturbine offers...
low maintenance
, small packed, efficient unit
It looks OK for vehicle usage as well.
Jim Wilkins said:but possibly the most reliable, well built piece of outdoor equipment I have
is a 1955-ish motorized
reel lawnmower.
