ps/2 port on a pc
Randy Day
I have an old DOS (yes, DOS) laptop that I want
to use in a project. I want to have two-way
communication, but the ONLY port this thing has
is a ps/2 port.
I can find lots of info on sending chars TO the
PC, but I can't find anything on sending
characters OUT the port to my micro. Is there a
register I can POKE, an interrupt I need to call?
I have QBasic on the laptop, so I can PEEK and
POKE as necessary.
Any advice is greatly appreciated.
Jasen Betts
is a ps/2 port.
the port doesn't communicate in characters it commnicates in bytes,
if you haven't got a copy of RBIL yet, get one.
IIRC this is covered in PORTS.TXT
POKE as necessary.
There were things you could do on some keyboards that would crash
GW-BASIC, I don't recall if QBASIC was also succeptible,
It it possible you will need to write an ISR, so youd'd need something
stronger. I know "Turbo C 2.0" is a free download from Embacadero after
registration. or DJGPP if you have a 386
Randy Day
[email protected] says... said:
The keyboard has very little output capacity but you can send a code out
I've seen any number of sites that say you CAN
send characters, and that describe the protocol
for communicating, but none of them talk about
the how-to's from the pc side.
to light the number lock, caps lock and scroll lock leds. Look those up
might find some information for you. There was also a hobbyist made usb
password dongle on the web. If you can find it, it has information on what
codes (and a little of how) are sent. The usb thing is just an interface
the registers to poke and peek will be the same. Ideally you should use
the serial port.
Believe it or not, this laptop only has one
i/o port: the ps/2 port. No serial, no lpt.
I will do some searching on the blinking
lights thing, though. Thanks.
Randy Day
[snip]
Oo! Interesting! There is indeed a
section on the 804x keyboard controller.
I'd be ecstatic if all I had to do was
check a status bit, drop a byte into
60h, and have the controller handle the
actual signalling. Can it really be that
simple? Time to fire up the 'scope!
If it is, I'm sure I'll find out! ;)
Jasen Betts
That's sounds about right, it's been 20 years.
Michael Black
is a ps/2 port.
What kind of laptop has no serial port or parallel port, or PCMCIA slot
for such an interface?
For that matter, what kind of laptop doesn't have any of that, but has a
PS/2 port? The PS/2 port is used for a keyboard, and I can't think of any
laptop from back then that had the port for an external keyboard, that
sort of thing came only when USB started becomiing the norm. Or PS/2 is
used for connecting a mouse, but a DOS laptop isn't likely to have much
use for a mouse to have the port, and before mice were standard, often
other interfaces were used (like serial port, and a card the expansion
bus).
It seems most likely you think you have a ps/2 port but likely it's
something else.
If the laptop has a parallel port, back then the parallel port was
generally one way, except it had a bunch of status lines to read from the
printer, so one could do an odd two-way communcation through a parallel
port, there was a whole "standard" for this. If it's serial, then you
just communicate over it, everything's in place.
Michael
W
whit3rd
Probably a contracted model that just acts a a terminal to a
bar-code scanner. That kind of setup was pretty common for a
few years, for inventory and warehouse folk to hang on their necks.
Randy Day
It does have 2 pcmcia slots, but I'm not
going to spend money on cards or time on
finding drivers. The port only has to
transmit a few command bytes to the micro
once in a while, so emulating a kbd is more
than adequate.
The brand may give you a clue to its age: "Digital".
The port does work with an external keyboard, and
there's a mouse symbol as well as a kbd symbol next
to it, so I assume it can do double duty.
bus).
something else.
No, it works with a keyboard. The machine does have
an integrated trackball, but I've never tried to
test that.
Now, *maybe* the unit ran an early version of
Windows, but it's got DOS loaded, and even
navigating menus in QBasic shows some lag, so I
don't think it was a speed demon even in its day.
However, the display (320x240!) is flawless, and
the unit does a mean spreadsheet, so I'd like to
repurpose it; it'd make a good console for a
logic analyzer or other uC project.
Jasen Betts
barcode scanner could be RS-232 or PS/2,
Jasen Betts
With the right a splitter cable you you should be able to attach both
simultaneously.
test that.
What CPU? if it's got ps/2 mouse I'd expect at-least 80286
petrus bitbyter
Randy Day said:
[snip]
Found RBIL no problem but not PORTS.TXT.
Suppose this document covers the problem as well,
http://www.computer-engineering.org/ps2keyboard/
though I like to find PORTS.TXT as well.
petrus bitbyter
Randy Day
[snip]
According to the interwebs, it has a 486DX2/50.
Maybe the fact that it has a 'government salvage'
sticker on the back means it picked up a few bad
habits working for the government! <g>
bus).
something else.
Michael
I've got a magnetic card reader/writer. I have an old Inspiron 4100 that
I have to use with it since it has both the PS2 plug and a real serial
port.
All the PS2 connector does is supply the 5V current for the thing. The
serial port is where the action happens.
