Topic of this particular trivia quiz was "general, pre-microprocessor
electronics" when posted verbatim to sci.electronics in 1988 -- the
newsgroup was then several years away from fractioning into its current
seven subgroups. (Answers appeared a month later.) This quiz also
circulated to some undergrad EE students at a respected school and it was
hard to find any who could answer even one question completely, unremarkable
because subject matter is not taught in nor prerequisite to contemporary EE
training but reflects practical practice, some of it well obsolete in 1988.
Obsolete but not unworthwhile and besides, as Jim W'ms would say, cool. (I
feel certain that students of Tom Lee, at least, would do well with this
quiz.) It provoked exchanges among constructive sci.electronics regulars in
1988 -- of those, I espy none today but Bob Myers KC0EW -- Bob, please be
so gracious as to email if you see this, your postings are prominent in my
archives, along with those of D. Tutelman, B. Niland, R. D. Pierce and his
analectic Anecdotes; Scott Dorsey despite remarks on transistors in
[email protected]>, 1987; several constructive audio contributors
including Francis Vaughan of Adelaide U. who with others kindly archived my
online notes "Oversampling for the curious, the furious, and the damned"
(accessible now by direct Google search or at, for instance,
http://members.chello.nl/~m.heijligers/DAChtml/Digital Theory/hauser.txt),
and finally Norm Strong, whom you'd all best be nice to, and not just
because he knows many different ways to blow things up should the need
arise, of course for entertainment purposes only -- Just Like This Quiz.
1. Assuming that you are acquainted with the "cascode" configuration, do
you know where the term came from?
Nope.
[Note! My 1988 answers had this wrong, reflecting a popular myth of which I
was later disabused, but a myth that also made it into the current revision
of a venerable analog-IC text, despite my efforts by sending the accurate
reference to those revising the text, upon their request to me at the time
for historical information. Enough About That.]
2. What is a reflex amplifier?
One gain stage that amplifies two separated frequency ranges,
typically RF/IF and audio.
3. What is the basic principle of a superhet receiver? Of a regenerative
receiver? Difference between a mixer and a converter (in RF)?
Yawn. Same?
4. Who developed the op amp, and when?
Dunno, but it's basicly in the MIT RadLab books.
[2004 Note: Question 4 preceded George Rostky's excellent recent historical
articles in the trade press, which I recommend, and which themselves have
now achieved misquotation elsewhere. That and plagiarism may be today's
"sincerest form of flattery."]
5. What is the "purple plague?"
Gold-aluminum embrittlement.
6. What is a class-C amplifier and where is it typically used?
Low conduction cycle; tuned RF power stage.
7. Can you describe a tunnel diode? A unijunction transistor? An SCS?
(What is the basic principle of each and what are they used for?)
TD: Esaki super-abrupt junction; has forward conduction peak. Sort of
a negative-voltage zener.
UJT: one rectifying contact on a slab, ohmic contacts on the ends.
SCS. Silicon-controlled switch. Obsolete. Sort of a GTO?
8. Traditional op-amp ICs were made whenever possible to run on +- 15
volts. Why that voltage?
Donno. Sounds interesting.
9. What do the following acronyms stand for: PDP, VAX, ASCII, EBCDIC, PRV,
BFO, RTTY, CW, VSB, VOR, Conelrad?
Programmed Data Processor. Virtual Address Extension. American
standard code for info interchange; extended binary code mumble
mumble; peak reverse volts; beat freq osc, radio teletype, vistigial
sideband, vhf omni ranging, some civil defense signalling mumble.
10. What was revolutionary about the 741 op amp?
Internal comp; no latchup; no diff mode zenering; decent current
limiting; lots of popcorn noise.
11. Can you specifically describe the US semiconductor products known by
the following terms:
1N34 point contact radar diode
CK722 cheap Raytheon PNP, nice blue/purple can
2N107 cheaper Ge NPN
2N2222 generic NPN silicon, oscillates whenever it can
2N3055 universal TO-3 NPN power gadget
uA703 crappy opamp
uA709 slightly less crappy opamp, external comp
SUHL Sylvania Universal High-Level Logic
Utilogic, Signetics weird hybrid logic, useless except for the Unibus
receiver
COSMOS RCA's name for 4000 series
Intel 1101 early DRAM
Intel 1702 early EPROM
12. Identify the following trademarks: Nixie, Pixie, Numitron?
Neon numeric display, unknown, ugly RCA incandescent numeric display
13. What is a thyratron? A magic-eye tube? A compactron?
Hot filament gas triode/tetrode, a glass SCR. Hydrogen are still used.
Vee-shaped fluorescent display, tuning indicator
Lots of toobs in one toob.
14. What magnitudes of voltages are required for operating the following
devices: Neon bulb, Xenon flashtube, Geiger-Mueller tube, Esaki diode.
80, 500, 800, 0.15
15. What IF frequencies are traditional in the US for AM broadcast, FM
broadcast, TV sound, TV picture?
455K, 10.7M, 4.5M, 45M. Not sure about the last one.
[2004 aside, for any who haven't heard this: European engineers have
quipped for decades that TV signal format acronyms stood in the US for
"Never The Same Color" and in France for "Système Envelloper Contre les
AMéricains."]
16. What is a Hartley oscillator? A Colpitts oscillator? A Pierce
oscillator? A Wien-bridge oscillator? A blocking oscillator?
Tapped L; tapped C; plate-grid LC net; RC-CR phasing network; thingie
with pulse transformer feedback (relaxation oscillator, makes pulses,
can make freq dividers, oscillators, one-shots, very cool.)
17. Quick, without calculation: What voltage corresponds to zero dBm in a
600-ohm circuit?
around a volt, 0.7 maybe
18. What is an Eccles-Jordan circuit? A polyflop? A switch-tail ring
counter? A Johnson counter? An AC-coupled flip-flop?
flipflop; 1-hot flipflop; shift register eating its own tail,
backwards; shift register counter; just what it says.
19. In the context of filters, what, formally, does "biquad" mean? (1988
note: Most engineers get this wrong.)
Informally, a pair of cascaded integrators etc.
20. What does it mean when a resistor is marked with bands
red-yellow-green-silver? A capacitor with "104K?"
2.4M 10%; 0.1 uf
21. If an aluminum electrolytic capacitor is rated for "working voltage" of
10 volts, in what range of voltages is it designed to operate?
-1 to +10
22. Roughly compare ceramic, polystyrene, and polycarbonate capacitors.
too obvious
23. What is a "2 1/2 D" core memory plane? (You could not open a computer
trade magazine in, say, 1968 without seeing incessant references to them.)
you save from having full x-y drivers by adding a fourth inhibit
winding.
24. What is a couplate? A micromodule? Difference between thin-film and
thick-film hybrid circuits?
Sounds obscene; little welded cordwood thing, impossible to fix;
screened/fired versus vacuum deposit.
For you:
