Good evening everyone. I have signed up to your forum as I have a problem with a new alternator that I have fitted to my car and just can't seem to find the answer from the auto electrician world. I'm hoping someone here has the answer.
I am an ex motor engineer with a basic knowledge of electronics. This is the problem.....
The alternator on my car stopped charging so I fitted a NEW one. I have done this many times in the past to new and old cars and have never experienced the problem this one has caused.
The new alternator had the exact same connectors as the old one and everything fitted perfectly. The car started and the volt meter on the dash and confirmed by a multi meter across each battery (it has two in paralell) read 14.3 volts. The problem is that when the ignition is on and the engine not running (alternator not turning) a relay in the engine bay fuse box buzzes. As soon as the engine is running the buzzing stops. It did not do this with the old alternator.This is what I have found out so far:
The function of the relay is to COMPARE the voltage from the battery to the voltage from the Alternator's OUTPUT lead. When the Alternator is HIGHER, the "coil" in the Relay [an electromagnet] moves the internal switch and connects the Alternator-output to the Battery - thus charging the battery.
The Relay is INTENDED to switch BACK [i.e. disconnect the battery from the alternator-output] when the voltage of the Alternator is BELOW that of the battery - thus saving the BATTERY from accidental discharge when the alternator IS NOT being driven by the engine [or becomes faulty!].
The relay is buzzing (switching on and off very quickly) because the voltage to it when the engine is not running is too low. I have not tested exactly what the voltage is with the ignition on and engine not running but have been told it is about 7.6v.
I have been told that new alternator may have been fitted transistorised rectifier/regulator which does not allow a constant milliamperes draw hence the fast on and off of the relay causing it to buzz.
Will it be possible for me to identify the rectifier and regulator in my old alternator so I can buy them and fit to it?
