My Vintage Dream PC
Rostyslaw J. Lewyckyj
FatBytestard said:
Sorry, dumbass. I know how hard it is for you to follow and keep up
with modern times. Are you still running Windows 95? I would not be
surprised.
A single, 1.5TB drive can hold 50 of your 30GB daily backups. 50 times
your $2 DVD is 100 dollars, which is not far off the reliable hard drive
price, idiot. That is uncompressed. It would hold far more with
compression.
Yeah, yeah, and if that 1.5TB drive croaks you lose two months of
history (backups).
Keeping them on separate media is a safety feature.
John said:
They vary from about 2 years old to just-purchased. The exact same
machines!
So how much actual use time does your oldest computer have on it?
16 x 2 =32 and 20<<32. So they really don't have that much time
on them. They are really just past their burn in ages.
Baron
John said:
On Wed, 03 Jun 2009 22:46:37 -0700,
JosephKK wrote:
JosephKK wrote:
JosephKK wrote:
JosephKK wrote:
On Fri, 29 May 2009 09:13:22 -0400, jmfbahciv
Peter Flass wrote:
Scott Lurndal wrote:
What you will see going forward is that the operating
sytsem(s) never really touch
the real hardware anymore and a VMM of some sort manages
and coordinates the hardware resources amongst the
"operating system(s)", while the operating systems are
blissfully unaware and run applications as they would
normally.
We've seen this since CP-67 in, what, 1968?. BTDT.
If the OS doesn't touch the hardware, then it's not the
monitor, but an app.
I think this one is currently an open ended argument. What
do you call an application that hosts hundreds of
dynamically loaded user applications?
A daemon.
That is way far from the usual definition of daemon. Check
your dictionaries.
Since we implemented a few of them, I know what the
functionality
of our daemons were. You asked me what I would have called
them. I told you.
Yes you have. I basically come from the nuxi model.
Particularly when that application used to be an OS in
its own right?
Which one are you talking about? The emulators are running
as an app.
You are missing the boat here, in the current world there are
several cases of things like virtualbox, which run things
like BSD, Solaris, MSwin XP, Freedos, (as applications) and
all their (sub)applications "simultaneously" (time sharing,
and supporting multiple CPU cores). This would place it at
the monitor level you have referenced.
No. Those are running as apps w.r.t. the computer system they
are
executing on. Those apps will never (or should never) be
running at the exec level (what the hell does Unix call "exec
level"?)
of the computer system. That is exclusively the address space
and instruction execution of the monitor (or kernal) running
on that system.
It is kernel space in the *nix world.
In olden unix' world. I'm beginning to have some doubts based
on what's been written here. It looks like a lot of things
get put into the kernel which shouldn't be there (if I believe
everything I've been told).
Terminology is failing here.
It's not a confusion of terminology. It's more a confusion
of
the software level a piece of code is executing. I run into
this confusion all the time. I think it's caused by people
assuming that Windows is the monitor. It never was.
MSwin never was much of a proper OS. Just remember that
there are more things claiming to be an OS besides Multics,
RSTS, TOPS-10, VMS, MVS, VM-CMS, Unix(es), and MSwin.
MS got Cutler's flavor of VMS and called NT. They started out
with a somewhat [emoticon's bias alert here] proper monitor
but spoiled it when Windows' developers had to have direct
access to the nether parts of the monitor.
/BAH
Yep, just like the ruined win 3.1 by insisting on embedding the
32-bit mode within the GUI, and insisting on internals access.
More yet of the tiny basic mentality.
Nah. It got started a long time ago, when the founders of MS
discovered a listing of DAEMON.MAC (of TOPS-10) in a dumpster
and believed they had a listing of the TOPS-10 monitor when they
read the comment
"Swappable part of TOPS-10 monitor". It was a user mode program
that ran with privs.
/BAH
Wishful thinking. They were not smart enough to recognize the
value of such a document, let alone understand it, even if they
did find such.
You are wrong. They were clever enough; they simply didn't take
enough time learning about what they were using. I guesstimate
that one more month of study and they would have learned about
how buffer mode I/O should work.
Are you so very sure? They used DMA to read/write to the floppy in
the original PC. Used DMA again for the XT fixed disk as well.
They got into the habit of mucking with BIOS and DOS from the
beginning, the hardware could not detect it let alone prevent it.
Then, when better hardware came along they would not give up the
foolish practices, and still haven't.
You don't know history.
/BAH
Which history do you know? I have been watching computers since the
core days and even worked with core computers.
Unless i am mistaken the DEC-10/PDP-10 used only silicon ram.
Early PDP-10's were core memory for sure. I don't know about later
ones... probably DRAM by that time.
I still have some core planes around here somewhere... They were
electronically nasty, amps of X-Y drive and millivolts of sense line
voltage, all tangled up, temperature and pattern sensitivity all over
the place. Some people did it right, some didn't.
John
I do not find your description credible.
The only explanation for that is that you didn't work much with fast
core memory at the electrical level. Did you?
Or rather absurdly and
unevenly exaggerated.
Lots of minicomputers had flakey core memory. As I said, some people
got it right and some didn't.
I know damn well that drive currents were not
that large.
Half-select (X or Y drive, or inhibit winding) currents ranged up to
maybe half an amp each. A core stack might have many such drivers.
That's a lot of fast stuff to have woven into a sense winding that
might make 50 mV on a good day.
The temperature sensitivity is exaggerated
Exaggerated by whom? Not me. The cores were temperature sensitive, had
to be sensed and compensated, and banging on one address the right way
could seriously heat one core.
as is the
pattern sensitivity;
Well, pattern sensitivity diagnostics were standard. Keep your trimpot
tool handy.
in fact early silicon DRAM had far worse thermal
and pattern sensitivities.
The semis got fixed.
"Quirks"...
http://www.psych.usyd.edu.au/pdp-11/core.html
Yup. PDP-11 core memory was indeed quirky.
The worst core memories were dense and fast. At low density (big
cores, few cores per sense line) and slow access times (a few usec)
they could be very reliable.
One juke box that I know of stored user selections in _big_ cores...
one core per record (where "record" is a 45 rpm platter, not a C
struct.) Pressing the letter:number select buttons magnetized one core
- XY-select! - and the mechanical platter scanner selected and read
out the cores as it passed the record storage slots. If the power cord
was yanked, as tends to happen in certain bars, the paid-for
selections wouldn't be lost.
John
You beat me to it ! The "Seburg" was a real monster. Could loose a
finger if you weren't carful.
Archimedes' Lever
Whwy you loas an argument based on the facts - which of course you
always do - you cut over to insults.
Weasel.
John
There was no argument. I did not lose anything. I merely stated that
you are a goddamned liar for the remark you just made. I stand behind
that reference to you, John Larkin. You, John Larkin, are a goddamned
liar.
Does that make it any more clear to you, asswipe? It was not an
insult, it was a declaration of fact. Calling you an asswipe just now
was the insult, you dumb, illiterate, retarded bastard.
I wish you would learn how to read. Your retardation level is like
wading through a swimming pool full of shit and claiming to have free
money at the bottom of it.
Archimedes' Lever
The paradox is that big systems are assembled from small chunks,
usually smaller than one on my apps, but have bugs. The bugs are
usually *within* those small chunks.
Stating the obvious... again. I'll bet you can add one and one
together as well.
You're a fucking joke.
Archimedes' Lever
OK, what do you do that really needs more compute power than my
dual-core Xeon?
What do you do at all?
John
Dual core xeons are old hat, dumbshit.
I find it hilarious that you suddenly forgot what computer horsepower is
for.
Archimedes' Lever
, really good drivers,
stuff like that.
Unless the asswipes decide to ignore a driver need. Who are you gonna
call?
Their 9600 model printer lost support even at the XP level. They killed
development on it before it was even a year old.
They figured since they didn't sell that many, and since they
had a new model, they did not need to support the original model.
I despise selective bastards. Kind of like you are with your "asshole
attitude on" asshole attitude off" presence here. in reality your depth
of knowledge of the personal computer realm is pretty lame.
Archimedes' Lever
What's wrong with a six year old design, except that the bugs have all
been worked out? It's a dual-core 1.9 GHz Xeon, ecc ram, RAID drives,
redundant bios, fans, and power supplies. Zero problems so far. The
engineering gets done without interruptions from computer problems.
How can anybody but a gamer object to that? Should we add glass
porthole covers and neon lights?
What do you do that needs more compute power?
My PC doesn't sport any "problems" either, dumbshit.
I could put together an El Cheapo bare bones machine in today's
electronic industry and it would not sport any problems either, aside
from being slower.
You really are thick, asshole. You are the one sporting problems here.
I find it funny that you were hypnotized by someone into thinking that
your machines are more reliable than others because it carries a moniker
with the word "reliable" built into it.
I'll clue you, it ain't built into their box either. It is just
another PC. You're a fool if you think otherwise.
Archimedes' Lever
How big was the TOPS-10 monitor?
I'll take that answer in words, since bytes hadn't been invented back
then.
John
Byte:
Circa 1962 dumbass!
TOPS-10:
Circa 1970
Again, you sport simple math issues.
Archimedes' Lever
Here, the file server is the company library. It isn't the backup, it
_needs_ to be backed up. Off site. Reliably.
Flinging around acronyms can't change that reality.
John
You are a total retard. You starred in the film!
The NAS device IS the mobile, off-site device, idiot!
You put it on your server, and you mirror your server to it. You take
it with you at night. You could even keep another one in a fire safe to
have yet another.
It isn't about choosing to speak using an acronym, you retarded piece of
shit.
It is about you being too goddamned stupid to know what reality is.
You are worse than a horse with blinders on. Your bent attitude has you
posting with your thumb up your ass every time. Learn to read, dumbshit.
You wouldn't know a globally accepted paradigm if one bit you in the
ass. Oh... too late. It's true. You are too stupid. Your degreaser
factoid proved that. Funny. Absolutely hilarious.
Mycelium
Trollfeeder. ;-)
Cheers!
Rich
I guess that makes you the obese troll that stayed in the shadows
enough to go un-noticed, lard ass. Except, that is, by observers that
actually have brains, like me.
Archimedes' Lever
history (backups).
WRONG! ANY previous day's backup will get you what you are after,
dipshit.
Also, the odds of ANY of the backup drives "croaking" as you put it are
less than your always on server's drive. Far less.
Do you honestly think that real, properly operated businesses are
backing up onto DVDs on a daily, full backup basis?
You have no clue what the word overkill means. Except you are doing it
on volatile media. Far more volatile than magnetic disc storage devices
could ever be.
F
FatBytestard
Most are about 2 years old; we just bought 4 more. And I said "about
20."
The best part, aside from the reliability that you question, is the
five spares down the hall. If any PC breaks, we just replace the box,
move the plug-in drives, and power back up. I did it in under 15
minutes, after I blew out my serial port doing something silly.
What kind of PC do you use? If it dies, how long will it take you to
get another machine and set it up, with all the apps and settings and
projects and mail and everything restored?
John
Why do I hear violins?
Bwuahahahahahahahahha!
Archimedes' Lever
That was Seeburg, and all the brands had "monsters".
Could loose a
Or if you were merely too stupid to be working in the industry.
Some people shouldn't have driver's licenses or be behind the wheel of
a vehicle either, but we let 'em do it.
Look at who less than half the country put into the highest office!
To me, that means that at least half of you are IDIOTS!
Bwuahahahahahahaha!
Richard Cranium
You are a prime example yoursaelf Archie. Look at who mommy lets sit
at a computer!
Bwuahahahahahahahahahahahahahahahahahahahahaha!
Richard Cranium
On Fri, 05 Jun 2009 19:23:23 -0700, Mycelium
Except, that is, by observers that actually have brains, like me.
You Archie ... have brains?
Richard Cranium
On Fri, 05 Jun 2009 18:54:39 -0700, Archimedes' Lever
<<<<<Snip>>>>>
Archie calling John a liar?
What about your claim of celibacy Archie? Is that a truthful
statement?
Richard Cranium
together as well.
Then why is everyone laughing at YOU!
Richard Cranium
Yup - the only way for you to get any positive feedback is to author
it yourself.
Jesus loves you ... everyone else thinks you're an asshole!
