Ill
So.. I've used some other images.
Notes/Step-by-Step:
Power is connected to pin 2 on each regular relay.
Power is connected to Timer/Relay 'common' output terminal.
Power is connected to a 'Normally Open' push-button.
Other side of Normally Open push-button is connected to Timer/Relay 'Vcc'.
Battery negative is connected to Timer/Relay 'GND'.
Battery negative is connected to pin 1 *and* pin 4 on each regular relay.
Timer/Relay Vcc will also connect to a 'Normally Closed' push-button.
Other side of Normally Closed push-button is connected to Timer/Relay 'N/O' output terminal.
Timer/Relay 'N/O' output terminal is also connected to pin 8 on only one of the regular relays.
Timer/Relay 'N/C' output terminal is connected to pin 8 on the other regular relay.
Remaining pin on each regular relay goes to the actuator. (you can swap these wires to make the actuator move in the desired direction)
When 'Normally Open' button is pressed, power will be supplied to the Timer/Relay. The Timer/Relay will 'click' and provide itself with power through the 'yellow' wire. The button can now be released. The Timer/Relay will also provide power to one of the regular relays which will reverse the power to the actuator causing it to move.
When the Timer expires, the Timer/Relay will unlatch and will remove power to itself & the regular relay. Power will then flow into the other regular relay through the blue wire and provide power to the actuator in the 'normal' direction.
The 'Normally Closed' button is an 'over-ride' ... if you want to cancel opening the door, or need to close it before the timer expires, this button will forcibly turn the timer off and cause the door to begin closing.
** There are simpler methods to do this, but this particular method is built so that at any point in the future you can add-on or alter the circuit incredibly easily. Additional 'safety' sensors or switches can be easily connected at a later date if you feel they should be used.
How does this look to you? If you need any clarification, please let me know.
