Sorry, missed that last post.Hi again I'm probably going to need to be babied through this if you can please
Thanks Mark
Do you know if the actuator you have has an internal limit switch on both ends of travel, or just on one end?
Thanks Mark
The circuit will work, But 40 seconds may as well be forever as far as a dog is concerned! ours go in and out in less than a second! I suggest you use a lever to open the door, a very long lever on the door side and a very short lever connected to the actuator rod. Then set the limit switches so the actuator stops when door is open.Hi I am electronically illiterate so you might have to go slow on me please . My project requires a 12 v circuit design please .
The idea is to open and close small dog door with a 12v 3 amp actuator
The actuator takes 40 seconds extend and 40 seconds to retract. I hoping to be able to push a switch / button which will connect to your circuit suggestion which will extend the actuator rod and to its full length Which takes 40 secs then retract the actuator rod without pushing the switch / button a second time ? Your help would be much appreciated . Thanks Marks dog door.
We can make this work.Hi gryd3 the timer has arrived I think it's what we are looking for - Marks dog door
It sounds like it has a limit switch on both ends of travel, that is great considering the description made it sound like there was only one limit switch inside...Hi again thanks for your time - it sounds good - the motor extends the actuator to its full length (which is what I need) then stops and disconnects itself from the power (I think this is what you mention as open ended) then if you swap the red and black motor wires to the opposite battery terminals it withdraws the actuator to its fully closed position (also the position I need ) then rests or disconnects itself from the power supply - mark
Excellent!I've up loaded a picture of timer and relays relay s only have 5 connecting points each
And dumb question where it says 12 v all 3 wire to the same battery terminal ?Ok wish me luck
Yessir. All 12V together, and the downward arrow is the negative terminal. Those all all together too.And dumb question where it says 12 v all 3 wire to the same battery terminal ?
S1 starts the process, and the timerRelay latches which continues the process.Sorry also - s1 switch starts the process - but I'm not sure what s2 is for ?
