GonzoEngineer, I've never had reason to use an IGBT in this manner, and I'm simply considering it to be a mosfet with different characteristics
How do you calculate the turn on time for an IGBT based on the available gate current? I note that the gate voltage tents to follow a similar curve to a mosfet, but the
datasheet doesn't mention the gate charge as such (I presume "On State Gate charge" is the magic number).
Looking at figure 16 in that datasheet is seems that most of the switching occurs with the gate voltage between about 6 and 7 volts and over a charge of about 10nC. Would it be reasonable to (as a ballpark figure) to assume switching occurs in the time it takes to transfer this 10nC of charge to the gate? I'm assuming that the earlier portion of the charge effectively gets you up to the Vgs(th) and that further charge us essentially superfluous as the device is beyond it's linear region at that point.
If so, a 10k resistor from a 12V source would transfer 10nC across (say) 6.5 volts in about 15uS? -- and that's somewhat faster than I expected.
