Hello.
I hope you can help me out with this one. I am looking to build a multi path signal switch for my guitar gear (rack).
I was going to use two simple rotary switches, one 5 pole and one 3 pole, both 3 or 4 throw. I really only need three positions but 4 is nice to have in case I add a unit later on.
I would also add a 9v circuit for some leds to indicate what I have chosen.
Do any of you know of any "chips" that can replace 5 pole 3 or 4 throw rotary switches and not degrade the audio sound?
My initial plan was to do the following with the switches. Let me use 5 pole 3 position and 3 pole 3 position as an example here:
Switch #1
Pole 1: Guitar -> 3 x pre-amps
Pole 2: 3 x pre-amps -> Power amp
Pole 3: Leds
Pole 4: 3 x pre-amp effects send - > Pole 1 Switch #2
Pole 5: Effects signal -> 3 x pre-amp effects return
Switch #2
Pole 1: Effects send from pre-amp -> 3 x effect units
Pole 2: 3 x signal from effects units -> Pole 5 Switch #1
Pole 3: Leds
A pretty simple circuit, but it is actually not that easy to find these switches. When I do find them they cost like 3 bucks and are some old military stuff from Soviet or cheap looking ones from China so I am not sure they're durable or any good for audio circuits. Also, it's cool to have one of those fancy pantsy small smooth turning knobs that just controls a "chip".
I have an AVR dragon if I need to program anything, but I know too little about the different "chips" to go out and just pick one up.
Any help here is appreciated.
Thank you.
Vegard
Switch #1
Pole 3: Leds
Switch #2
Pole 3: Leds
Thank you.
Vegard
