Phil Allison
got myself one of these a few days ago:
http://dicksmith.com.au/product/GE6831/dick-smith-28-5-quot-72cm-hd-led-lcd-tv
Currently on special, for a mere $199.
Has both analogue and SD/HD digital tuners plus facility to use a USB
storage device for record and playback.
While I have nothing really to complain about - the specs leave out
things, are ambiguous about others and have an error.
First, it does not weigh 21kgs - fully packed, the weight is about 8 kgs
and the set alone is 5.5 kgs.
The AC consumption is 65VA or about 36 watts.
The AC lead is attached and rather short - maybe one could cut it and fit an
IEC in-line female plug.
There is a hardware AC switch, easily accessible, under the screen - using
this is bound to extend the life of the SMPS.
Stereo audio output can be had from the mini-jack headphone socket ( at low
level ) OR from 2 x RCAs at high level - the latter having no remote
volume. The sound quality available is first class.
The inbuilt speakers will go quite loud, but have limited bass and treble
response.
The blue ON led is too bright, but easily tamed with a bit of opaque
adhesive tape.
While 72cm may seem small, viewable pic size is considerably bigger than
with a 68cm CRT and STB.
One nice feature is you get the new program title displayed for a few
seconds when channel changing.
Lastly, you can extend the warranty to 2 years for an extra $28.
..... Phil
response.
adhesive tape.
..... Phil
