Michael wrote:
Michael wrote:
Michael wrote:
On 2006-12-12, Michael
I'm working on a circuit that uses a NPN transistor to drive (i
think that's
the right word) two MOSFETs. Could someone please explain how to
work out
the theory behind it? For example what value resistors I need
between the
gates and emitter, etc. (i presume I need some). I'd like to be
able to work
it out myself as opposed to asking you guys for a 'solution' but
sadly I'm
struggling.....
what you describe suggests that you have the NPN transistor
manipulating the
voltage on the gates of the mosfets, that effects their
resistance.
not much more can be said without seeing the types of transistors
and how it's
all hooked up.
So far I've googled: driving mosfet, switching mosfet, mosfet,
mosfet
introduction, transistor introduction but to no avail....If it
really just a
case of wiring the MOSFETs' gates together and connecting them
directly to
the emitter? Any 'rules' to doing this sort of thing?
plenty of rules, the more info you give the better.
Bye.
Jasen
Sorry for not getting back sooner,
I've drawn you a schematic and uploaded it to:
http://www.mhims.co.uk/MOSFET Schematic.png
I'm trying to work out a suitable transistor (Q3) to use and it's
base resistor (R1) value... From what I've read in the mosfets
datasheet (
http://www.rapidonline.com/netalogue/specs/47-0530.pdf)
2-4V needs to be applied to the gates so that's where I get the 3V
value from and the 36V figure is from the onboard batteries (it's
for a robot).
Where should I go from here?
Michael
Looking at this, you could do the following:
1. Replace Q3 with a logic level MOSFET (the venerable VN2222LL
would be perfect), and change the sense completely. As shown, the
circuit really won't work that well.
Either use a PNP with emitter to positive rail or use a P-channel
MOSFET (Source to positive rail). If you need to drive with 3V or
3.3V logic, then there are solutions. The simplest fix here
(assuming 3.3V logic) and the fact you need 5V for gate drive (see
3) is to
a. Remove Q3 emitter from the gates and tie it to ground
b. Remove Q3 collector from supply, and pull it to the supply via a
10k resistor
c. Connect a 2N3096 with collector to gates, base to Q3 collector
via a 1k resistor, emitter to 5V
2. Add a pulldown from the MOSFET gates of 10k or so. There has to
be a DC return, and a resistor to ground is the simplest.
3. You need to provide a minimum of 4V to the gates of Q1 and Q2.
This is the only way you are guaranteed to exceed Vgs(th). Better
would be 5V, so change the power supplied to the collector [drain if
you take the advice in 1] to that level.
Note your TTL circuitry could be operating on 3V and the VN2222LL
would work fine as it would if it were a bipolar device.
4. I assume M1 and M2 are motors. As inductive loads, you need to
put diodes across them; anode to the MOSFET drain, cathode to
positive power for the motor. If you don't, the MOSFETS will operate
once, and at the first turn off, they will be toast (literally).
Cheers
PeteS
Ok thanks Pete....
Just to make sure I understand you correctly...are these right?:
http://www.mhims.co.uk/MOSFET Schematic2.png
OR
http://www.mhims.co.uk/MOSFET Schematic3.png
Michael
In
1. Change Q4 to a 2N3904 or a VN2222LL
2. Remove R2 or R3 (only one needed)
3. D1 and D2 should be across the motors, not the FETs
Then we're starting to get there.
Cheers
PeteS
Thanks, so this ok then?:
http://www.mhims.co.uk/MOSFET Schematic4.png
Cheers,
Michael
Your 2N3904 shows a PNP - it should be an NPN
Apart from that, you'll need some decoupling - put a 0.1uF cap from the
5V rail. The amount necessary on the 36V rail depends on the motors.
The DC ratings:
Use 10V or better rated for the 5V rail
Use 63V electrolytics on the 36V rail.
As a first cut, I would use 47uF on the 36V rail.
Cheers
PeteS
PS : I hope you are learning something
lol, I appreciate the help
This better?:
http://www.mhims.co.uk/MOSFET Schematic5.png
Where do the values of 10K and 1K for the resistors come from? I
presuming they aren't 'rigid' values.....
Cheers,
Michael
