Jamie
if you want my opinion? you need to use P and N Channel fets.Michael said:Thanks Chris,
Actually I was playing with the circuit today and hit something that's
puzzling me (I wired it as a h-bridge)...
Could you explain why when one the inputs (the little squares at the base of
Q1 and Q17) is high, the motor turns as expected but only 5.51V reaches it
with the 30.49V being dropped accross the top mosfets?
I'm guessing it has something to do with the load connected to the source as
opposed to the drain.....
Schematic:
http://www.mhims.co.uk/MOSFET Schematic5.png
Cheers,
Michael
unless i have missed something, only one side of the bridge is
actually going to fully conduct.
The last time i knew, the voltage between the SS and Gate must
be what spec calls for to fully turn them on. Seeing that you have the
motor on side of the Set SS side, I'm guessing that you will not get a
full bias to the Gate unless you're using boot strap type FETS?, in
which case, you will see a difference in readings.
I could be wrong, just and observation.
