I am using a signal generator to control the tuning of a radio. I am attempting to replace the potentiometer with a digital potentiometer and have it randomly tune the radio
That is a somewhat better description of what you are trying to DO, but it still includes an unexplained
requirement on HOW to use a signal generator to control the tuning of a radio. Why is that?
I thought you wanted to select a radio receiving frequency at random? How does a signal generator do that? Not saying you cannot do that, because I know from personal experience that it is possible, but I would like to see how you plan on doing it.
As seen in recent comments above, you are still not providing
enough information. In the end, it will be up to you choose to follow or adapt to whatever suggestions you receive here, but we here in the forum cannot make useful suggestions unless you tell us everything that is going on.
I am personally confused about what manually variable potentiometer you want to replace with a digitally potentiometer... is it a pot that controls the frequency of a signal generator (somehow) or is it a pot that (somehow) tunes the radio from station to station?
As I currently understand the problem, you have a radio that can somehow be tuned manually with a potentiometer-controlled signal generator. Is this correct?
Do you want to replace this signal generator pot with a digitally programmable resistor, so you can "sweep" the frequency range of the radio? This sounds a lot like the functionality of a so-called police scanner. If you have a particular radio in mind, please tell us what it is: manufacturer, model number, year it was made. Anything that would help locate a schematic for your radio. That could be very helpful in determining how to "couple" the signal generator to the radio for the purpose of tuning of the radio.
Or maybe the potentiometer in question, the one you want to replace with a digitally programmable resistor, is actually part of the radio, and you want to replace a manually-controlled tuning potentiometer with a digital potentiometer. So which one is it? The pot on a signal generator whose output somehow tunes the radio? Or the pot on a radio that you want to somehow "sweep" to select the receive frequency of the radio?
As others have mentioned, radios are designed to receive only a narrow band of frequencies within their tuning range. Broadcast AM, for example in the United States, is usually allocated a ten kilohertz band-widtrh for each station from within a broadcast band that extends only from 540 kHz to 1700 kHz. With band switches and other clever means, this passband can extended to be relatively large, but it is still finite. And broadcast stations are assigned very specific frequencies on which they may transmit and occupy radio frequency spectrum space.
In the old days, AM broadcast receivers used continuously variable tuning, so you could tune
any station that had a carrier wave signal anywhere in the range of 540 to 1700 kHz. That means hobbyists could cobble together an AM broadcast-band transmitter, put it "on the air," and receive the transmitted signal with any AM broadcast band receiver. There was no need to do this on any particular frequency within the AM broadcast band because the hobbyist didn't go through the bother of obtaining an FCC (Federal Communications Commission) station license. If you were careful to use a low-power transmitter, the chances of getting caught and having hefty fines levied against you, and all your illicit electronics seized was minimal. Don't ask me how I know this.
Then along came car radios. Folks wanted to "tune in" their favorite stations while driving... risky business trying to tune a radio while keeping eyes on the road while driving. So auto makers added push-button tuning, which just mechanically memorized the last setting of the tuning dial associated with a particular button. Many years later all that was replaced with electronic tuning and the pre-select mechanical buttons were replaced with push-button switches.
My ham radio transceiver (radio receiver and transmitter all-in-one) covers a range of 310 kHz - 32 MHz and 44-54 MHz; 144-148 MHz with KX3-2M option (which I do not have). This is NOT done with just one control being used to sweep this entire range of frequencies. A range of frequencies must be selected. Even then, my radio is tuned with a knob that drives the shaft of a rotary encoder, not a noisy potentiometer. This rotary encoder selects discrete steps in frequency, as small as one hertz, but also larger steps for rapidly tuning across a band. The frequency selection is NOT continuous because this is a software-defined radio, and software is always represented in discrete binary steps. Most other radios are not built this way. Either the tuning is fixed, like with Citizens Band radios, or it is continuously variable over a range of frequencies. Amateur radio operators (hams) are not assigned a specific frequency to operate. We are allowed to operate at
any frequency in
any frequency band which our license authorizes. So, almost all radio amateurs use receivers that "feature" continuously variable tuning, or like mine tune in very small increments of frequency.
So again, I repeat the question: what are you trying to DO with a digital potentiometer, a signal generator, and a radio? Leave it to responders here to suggest HOW you may want to do it. After all, if you knew HOW, you wouldn't need advice from us. Maybe you really don't even need that signal generator...
So, we need to know how many different tuning steps you need, and how much tuning-frequency change each step produces.
You have no doubt noticed that your 555 timer can be wired as a free-running oscillator, with the timing controlled by a variable resistance. Perhaps it is your intention to use a digitally-programmable potentiometer to control the 555 oscillation frequency, for some purpose you have not defined.
This is a digitally-controlled attenuation circuit used as a volume control. It will NOT do what you want, vary the frequency of the 555-based oscillator. Here we do not "sort of" want to do anything. We design circuits for specific purposes using real electronic components, although sometimes we will also use computers and simulation software to see if our design is "in the ballpark," or if it even works at all, as simulated.
Simulation is not the real world. The real world is real parts connected to form a real circuit that does what it was
designed to do. None of this "sort of works" is acceptable, except maybe by hobbyists with only a vague idea of HOW to accomplish their goal. Your stated goal is how to sweep the tuning of a radio in discrete but random steps using a programmable digital potentiometer. Right? If so, please tell us more about how a signal generator is supposed to tune a radio.
I used several digitally-programmable potentiometers (such as
this one) in the previous century to set gain and offset parameters in an analog circuit design that was part of a personal computer (PC) upgrade of a large analog electro-hydraulic servomechanism. Those pots were non-volatile. I could set a value and then remove power from the circuit and the pot would retain whatever value I set, just like adjusting a real trimmer potentiometer, except I could do it remotely, without a screwdriver, from anywhere in the world that had Internet service. Of course remote for this particular job meant the PC was just a few feet away.
