Sir bushtech . . . . .
If me, I would be using leaded transistors and a 2N2907 would be the PNP amd a 2N2222 for the NPN since they are siamese twins on their specs.
I would be shortening the stock leads just enough so that you would be able to swing their CBE leads around into PROPER pin alignment ( TRIPLE CHECK ! ) to their perspective pads, yet with them still being long enough to be able to result in a NEAT installation.
Be sure to pre tin the leads, so that they will then just rapidly melt into place on the solder reflow of their installation.
I was unable to get back in time for the full wave bridge diode conundrum, with its 4 discrete surface mounts (1N4007 equivalents) and was certainly just expecting 1 or more dead shorted diodes, as your problem.
The thing about this design, in its using an appropriately selected value of series capacitor to reduce line voltage on down to create a low voltage supply, is that it folds up on its power output, if being overloaded from the norm.
ERGO . . . with your controller IC receiving some degree of isolation by the totem driver transistors and the power supply folding back, we might now take a feeling for the pulsebeat of the controller IC .
Do you have a small pocket shirt size AM radio receiver ?
73's de Edd
People can be divided into three groups:
Those who make things happen, those who watch things happen, and those who wonder WHAT the hell just happened ? ? ?
