Platforms
Content
Sorry for the delay in responding. As the 2907 is a pnp device, the end of your detector that went to the FET gate should got to the Emitter and the end that went to the source should go to the base. There must be no other connections to the detector. Please note that the input resistance of your DMM must be at least 10MΩ if it is only 1MΩ, it will make a considerable difference to your readings.Thanks whonoes. I still have a lot to learn about electronics, so I battle to understand your advice, hence the stupid questions. If I connect one lead to the base of the (removed?)2907 where does the other lead go.?
The diode can be seen in the photo, the banded end points away from the resistor.
Ah, found it. My DMM's input impedance 10MΩ
