In alt.engineering.electrical [email protected] wrote:
|> |> | Batteries are the very heart of your system. That should tell you
|> |> | something about the choice of battery/ cell used. You sound like a guy
|> |> | looking for an excuse to use golf cart batteries.
|> |> You sound like a guy wanting to tell everyone to do things exactly the
|> |> same way you do things, without being willing to tell them why, whether
|> |> you actually know why or not.
|> | I have told you why, parallel strings do not charge/discharge in a
|> | uniform manner. That is the truth.
|> I'm not doubting the truth of this. I'm wanting to understand the means
|> by which this happens, and the degree to which it happens. I want to
|> understand this enough to know how well it may be mitigated. For example
|> the non-uniform charging may be dealt with by smaller chargers isolated
|> on each string (not one big charger trying charge the strings in parallel).
| It happens because every cell has a different internal resistance. You
| may see nothing wrong with spending the rest of your life trying to
| get several strings of batteries to a balanced state of charge but
| most peopls have lives beyong the battery room
This argument can also be applied to limit the number of cells in series, too.
Are you limiting your thinking about charging to one which only involves one
single charger system and charging all batteries together?
| Starting small and adding to a system is another false economy.
And you suggestion is to start out as big as you will ever need all at once
at the start, even though you don't need anywhere near that capacity now,
and may not for years?
|> I want to explore means to manage the load balancing before deciding.
|> Maybe it will be the case that those methods are not worthwhile. I
|> cannot say today. Today is the learning time. The decision is later.
|> The conditions will be known then.
| Start with your energy audit. Size a system to suit and play what if
| on paper for a while.
This does little good until _after_ one has all the scientific information
about batteries.
|> No. I want to know all the reasons for all the choices.
| Until you know what goes into system design you will fail to
| understand the relationship of the parts.
Until you are offering this level of information, what good is your advise?
|> What happens if you have ONE string of several very large cells/batteries
|> and one dies? Are you saying you don't have to replace the whole bank in
|> this case?
| That is absolutely right, one dead cell in a bank of batteries more
| than a year old, you replace the lot.
| Parallel strings are more prone to cell failure due to unequal
| charging.
But _you_ don't really know why that happens, and as a result of that, _you_
are not able to envision ways around it. But the important thing is, _you_
can't offer real scientific information because you simply don't have it.
All you have is specific "do what I (would) do" advice, and nothing more.
|> That is a work in progress. Much of it will be done when I start going
|> with some battery power. More will be done later. This is not a one big
|> step all the way project.
| You will find that is incorrect. You size a system to your need and
| build it.
Such an idealist. Maybe you should work in the _commercial_ UPS market or
something.
|> Quite a lot of it is unsupported "what to do" advice.
| Yep. that's often the case. You might try Swinbourne University and
| see if they will sell you the notes and work book for the
| "Introduction to Renewable Energy" course.
Is that a course on the science of how batteries work, or just a technician class
on how to install batteries using common "still thinking in the box" approaches?
|> Rectifiers are made of diodes (or other things).
| Yes that's right. They are used to change AC to DC.
That's not the only thing they can do. Do not assume that because there is more
need for one thing (converting AC to DC) that no other need (isolating DC directions)
is valid to consider.
|> |> |> I'm exploring all options. I'm not interested in specific advice on what
|> |> |> I should do (at least not without well explained why) ... I'm interested in
|> |> |> the information to make the best decision in the circumstances that will be
|> |> |> present at the time the decision is to be made.
|> |> | You still sound like a guy looking for an excuse to use golf cart
|> |> | batteries.
|> |> I am someone looking for the technical information that would be a valid basis
|> |> for deciding what circumstances that golf cart batteries can be used in, and
|> |> what circumstances they cannot be used in, where "circumstances" involves a lot
|> |> of things that I don't even know, yet.
|> | You can use golf cart batteries, they can be wired in series, parallel
|> | and series/parallel in as many strings as you feel are required. Most
|> | people only ever do this once. Their second battery bank is usually a
|> | single string of cells with the correct Ah rating.
|> And maybe I will migrate to that. One possible path is that I would start with
|> a small bank and migrate to a larger bank. I may parallel things in the interim.
|> I will also be looking at possible circuits to manage the load balancing between
|> parallel strings. Maybe that won't be practical. I'm sure you'll say it won't
|> but I want to know why, if that's the case.
| The reason why is that all cells have different internal resistance,
| so they all charge/discharge at different rates. As a battery a single
| series string has the aggregate of all the cells resistances and is
| basically balanced. Parallel strings must be constantly monitored to
| keep them in a balanced state of charge.
If the resistances in _series_ are different, that can result in an imbalance
as well. It's just more easily hidden becuase the single string still has a
behaviour like a single string. It charges up at whatever rate it can and it
discharges at whatever rate is demanded up to what it can. All this while one
cell is forced to go along until it dies. But you won't see it coming unless
you are monitoring each cell separately by some other means. And then you are
into the same amount of work to manage the system, anyway.
| And when it comes to using a hydrometer, a single string is a lot
| nicer to do than a number parallel strings.
For a moment there, I thought you might say that BIG MONSTER CELLS are easier
to measure than dozens of little batteries because the latter means taking a
measurement dozens of more times.
|> If it is the case that cost is why I would replace one cell/battery at a
|> time, then cost would clearly prohibit the monster cells.
| A single series string of the correct Ah rating will, with proper
| care, out last parallel strings. Good quality batteries will have a
| longer warranty that cheaper batteries.
But your advice is to not have any strings of batteries at all until such time
as one can have the biggest baadest string bought all at once. No economic
planning involved.
|> Apparently we have a different understand of this term. I don't know
|> what yours is, then. So it's pointless to proceed on this.
| Days of autonomy is how long your batteries will supply your daily
| load with no input.
I can't tell you what the future might hold in terms of the longest period
that might be when dealing with solar and wind sources. But I guess you are
the one with the crystal ball.
|> | Oh, I know what it is you want to know alright. But to understand you
|> | need to listen.
|> | You want some one to tell you what you want to hear.
|> You want some one to do what you tell them to.
| No, I have given you information. What you decide is your choice.
You have not giving me the information I seek. All you have given is advice
of what you think I should do, and simplistic reasoning (like "parallel will
charge unevenly" without considering mitigating methods).
|> I can see I'm not going to get anything useful from you.
| You got an awful lot if you listened. You are fishing for an answer
| that fulfills your idea of solar power. Reality may be different.
I don't have the idea, yet. I'm seeking scientific information (NOT The end
results like "batteries will charge unevenly") that explains what is going on
and what methods might exist to deal with it and manage it.
| Learn to size a system, play what if with the numbers, cost your
| sizings. Parallel strings are second best choice for home power
| systems and should be avoided wherever possible.
Learn the reality that size needs change, finances are not all at once, etc.
Lots of that might work in commercial UPS systems for companies that need a
short ride through an outage to maintain "five nines" uptime. My goal does
not include any "five nines" uptime for my home.
about batteries.
|> this case?
| charging.
| build it.
something.
|> |> | batteries.
planning involved.
| load with no input.
|> | need to listen.
