Sir notallbad . . . . .
Your last few add ons info, made me have to slightly re edit this entry . . .so as to be all encompassing . . . so here goes.
(Just now also saw that you added on, your having used BEKO's diagnostic code procedure)
You should now be OK on that U4 regs 5V output, so read past that info submitted verifying it.
But do catch all of the info on the the principal, higher 16V , being used for the 12 VDC supply for the mechanical relays driver coils.
Consulting my post #14's center photo note the 2 electrolytics around the LNK and also the two at the bottom center of the board.
They have been continually working, 25 hrs a day, in "burst" mode since the dryer was plugged into the power outlet, and being
even more taxed , at the times when the unit was operating.
If you have ripple upon them from evolved onset of ESR, that could account for the 4.7V . . .particularly if even tested unloaded.
The middle cap sets are for the in and out filters of the U4 5V reg.
So If you have no means of testing ESR, sub in some new or known good units.
Or if the unit has been running an hour or so, you can put
a fingertip at the bare metal cap top of a unit. A warm or hot one would signify a high ESR unit. If you happen to have or can access
a laser temp pistol, so much more the better in precise reading of temp differences .
((( I sees that you GOTS yerselfs . . . . a laser beam temp gun ! )))
Since you now have established the principal 16 VDC voltage that the power supply puts out and then reduces for the 5VC supply,
lets go to the top photo and track it. I see it originating at the right bottom corner of the LNK YELLOW BOX enclosure and traveling
up to the point where it widens and continues, but part of it branches off to feed its input to the bottom input term of U4. It also continues
up and branches off to go to the right on another feed at a 2 o clock position from U4 . It gets small and congested and I loose it.
Lastly it moves up and has to veer off to the left, 45 deg, to work around a cluster of 6 disrete parts. Then it slants 45 deg to the right and
then starts a course to the right to finally drop down to a pad of what I think being is one coil connection of the mechanical relay RL5.
Now of that cluster of two SM diodes, two metal SM resistors and two SM ceramic capacitors, I see NO additional relay driver transistor
for that RL5 ?
Looking at the affected central "light reflection" area, I do see, all lined up, 4 damping diodes for relay coils, with their driver transistors
just below them, so they must be for RL1-2-3 and 4's coils.
I do see a like arrangement of a single damping diode and driver transistor over to the right and a TACT pushbutton switch on EITHER side.
Could this be the remoted position of the RL5 driver circuitry, and are the pushbuttons being the units power on and off buttons ?
Also, I see some ancillary discrete RL5 components around its AC switching contacts . There are two series resistors, maybe like 10 ohms
that then thet tie into an anode of an unidirectional breakdown diode? . . . . possibly . . .that series combo, creating a snubber function ?
PLUS there is also another questionable electrolytic function ( What is being its capacitance + voltage r ating ? ) , that is being located near
the bottom left corner of the RL5 relay.
Are all of the relays solder connections, well flowed and looking goooooooooooood, and having no solder fracturing ?
Now in your wondering about the system U/Processor . . . I would be wanting to get ADEQUATE lengths of some multiple CAT 5 wires,
to use for hook up wire , to be able to solder tack one common wire to the shared emitter /grounds of all of the 4 relay driver transistors.
Then 1 wire each gets solder tacked to each of the 4 bases of the driver transistors,. then you remote out all of the leads other ends to get taped
onto a piece of cardboard and labeled.
THAT would THEN let you put the machines system all back together again for dynamic testing and go to the cardboard have one DC voltage
meter lead to the transistors shared ground. Then you can pick out driver transistors bases to monitor with the + meter lead to see IF and for what
duration ACTIVE HIGH LEVELS come into that base of a transistor to drive it and actuate its relay.
Thus validating, that there IS being U/Processor action.
Then you proceed as shown below . . . . to find out ?
See if this referenced procedure below is being applicable to your BEKO unit, as its very first test action MIGHT be resettting the system U/P .
Then . . . . . you can see that amongst the very first system tests, is being a validatuion of the buzzer and all of the LED's
validating their functionality, by their flashing at warp speed.
THEN you COULD fast forward testing by immediately speeding thru all of the heating modes, to get to its 7th? or 8th? test where the LEDS will
then again uber flash, at that speedy rate, and then the last push turns off the machine.
73's de Edd . . . . .
Now, I am proofreading all of this, being ever careful, so as to be sure and see if I have any words out.
